I am finally close to removing my Greddy TD06 manifold and Type R wastegate and install my 6Boost manifold to be used with the same TD06 turbo.
I hit a small problem as i have a new Greddy Type R gate to use with the 6boost manifold, but with a rough trial fit the big Greddy gate wont go close enough to the collector for the 6boost manifold to be able to provide good boost control
So left looking for a replacement wastegate. Looking around the 45mm mark and the Tial V44 or the Turbosmart Hypergate 45 look to be the best options. The Turbosmart gate is a tad shorter by 10mm but both appear to be far smaller then the Greddy gate and will be able to be packaged well.
Has anyone got experience with either of these gates being used on 6boost manifolds? Which is the best option and where is the best place to source?
https://www.sau.com.au/forums/topic/311467-tial-vs-turbosmart/
I use a Tial 44mm ext gate with my 6boost manifold, never had any problems. When I was looking around on what to purchase I did some research on these forums first. They both are pretty much identical in terms of reliability and performance according to alot of people. I ended up going for the Tial however cause my mate couldn't get in the Turbosmart through his work at the time.
Just don't skimp out and buy yourself a chinese copy because the quality is probably not as good and you might run into problems down the track with things like the diaphragm malfunctioning and the gate being stuck open. There's alot of nasty stories floating around with cheap ext gates. Purchase from a good, reputable brand and you shouldn't have any dramas.
Edited by GT32
Roy, I have not used a Turbosmart gate but I used to sell both and from past experience the Turbosmart gates are physically larger than most brands on average.
I would try to get your hands of both gates and trial fit the best you can.
Things may be different now so this point could be null and void.
Timing Roy , I know someone that just took a TiAL 44 of a 6Boost manifold on an RB26 and wants to sell it .
He went to a larger Turbosmart because the 44 wasn't big enough when the exhaust was increased to 4 and 3.5" .
Stay tuned , will be with the owner in a hour or so .
Cheers Adrian .
Cheers Adrian .
That could be a goer as its readily available. Some pics and a price would be handy
Doesn't Kyle only recommend the turbosmart 50mm gate?
He did when he made mine up.
He said he only stocks the Turbosmart gear these days, but said to go for either the 45mm Turbsomart or the 44mm Tial...he didnt seem fussed.
Shits me how you buy the Tial gate, then there is an extra $100 in getting the V-band flanges. FFS you think they would supply the thing with the flanges and clamps !
uh... all tial gates i've bought have come with one flange for the bottom and one flange for the side aswell as vband clamps for both of those...
Huh...they do supply the flanges and clamps with the gate.
Well they ones I bought were all supplied with the gate.
http://www.atpturbo.com/mm5/merchant.mvc?S...tegory_Code=WGT
Edited by juggernaut1
You may want to go larger, unless it's less of an issue on the 2litre.
In regards to wastegate placement and boost control. If I have ever supplied you or a friend with a turbo kit with a tial 44 for any kind of RB, when the order was placed the conversation would have been had that it is not good enough for the job, I do not recommend you use it, be aware X/Y/Y may happen, and if you must run it, and have boost control problems, do these things to fix it.
Original here:
http://www.supraforums.com.au/forum/showth...632&page=10
Edited by DCIEVE
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
