Hello All,
Some of you may have read my topic about suspension woes here --> http://www.skylinesaustralia.com/forums/Su...da-t309179.html
In it i was mentioning about the rear passenger wheel bearing being knackered... I took it to Tas Driveline and they were able to fix it for me, however there was something interesting that i found out in the process...
The Manual and Automatic Stagea have 2 Different rear wheel bearings...
Sorry but i dont have a pic, All i can say is that the manual one has a form of spacer on top of the bearing with a 17mm bolt hole through it that acts as part of the mount. It is a hub assembly (like the auto) but without that spacer on top the auto bearing wont fit in the Manual Stagea rear end...
So There you have it.... if you didnt know...
That excersice cost $370 for the bearing + labour....
https://www.sau.com.au/forums/topic/311492-stagea-wheel-bearing/
That's right, the manual and 206RS and some factory optioned LSD auto's (my auto did) have stronger drive shafts which means the larger hub bearings that you mentioned. They should be the same as R33 GTR.
Standard auto's should be the same as R33 GTST.
You can tell by looking at the half shafts out of the diff centre
The heavier ones (GTR) have 6x1 bolt pattern
The lighter (GTST size) has 3x2 bolt pattern
6x1 or 5x1?
Hi all just replaced rear passenger wheel bearing . My s2 auto used a cbc bearing . Part number NJ246 . This suits 200sx 7/94-2003,skyline 6/91-3/93 2.0l,skyline 6/91-3/93 2.6l 4 stud only,skyline 8/93 on 2.5l,skyline 8/93 on 2.6l 4 stud only. As for price $154.00 incl gst.
Great info... i will have a look into the part number for the bearing for my rear bearing aswell....
I did want to just say this.... I took the car to Ron's Automotive, Ronnie had a look at it for me (For a carton of our local finest) and found something quite interesting....
The front tyres were ROOOOOOTED... Out of round/out of everything, they may aswell have been made out of clag glue and paddlepop sticks... he checked all the links and mounts and found that they were "2nd hand" but definately not in bad condition. He said that with new front tyres and a wheel allignment that the thing would be fixed... So, Off to Jaxx i went... 2 new Pirellis and Bob's your uncle.... Fixedaroony... Top Bloke Ron...
So there you have it... Pedders Suspension test was going to cost me $3k to fix everything. And what it actually cost was,
Wheelbearing and new tyres and wheel allignment..
*note to self - that was a carton well spent...
  • 2 years later...
hi all
you guys are a wealth of information :)
has anyone found a generic supplier for the RS Four S (factory manual) rear wheel bearings?
from my searches, looks like i need the one with the little tab and bolt hole (same as R33 GTR?)
Just Jap have them for $350 :( ( http://justjap.com/s...&cat=375&page=1 )
how much labour should i expect to replace?
can i just get the bearing pressed out (and get new hub seals), or do i need that whole assembly?
thanks all :)
EDIT - anyone used allied bearings? http://www.alliedbearings.com.au/datasheets/nissan/wheel-bearing-kits#vehicle_make_1372
WebRep
Overall rating
This site has no rating
(not enough votes)
Edited by Stooge007
  • 7 months later...
hi all
thanks all :)
EDIT - anyone used allied bearings? http://www.alliedbea...hicle_make_1372
WebRep
Overall rating
(not enough votes)
Anyone know if the old bearings can be pressed out and replaced with new? Or do you have to buy the whole assembly?
