I am getting a bit sick of having a nice battery cover one one side of the engine bay while there is a gaping hole on the other side which has nothing but uglies on display (plus I'd like to hide the catch can ;))
I have ordered a G35 battery cover "kit" from the US which, I am told, will require cutting and at least 1 bracket to fit properly.
Will post pics etc when I fit it.
Now, I figure I can't be the only one that thinks this way (although it is a common occurrence :down:) so depending on how many people (if any) would be interested and how much needs to be done to fit it, I will look into a group buy in the not-too-distant future.
Cost will be a maximum of $160 delivered to your door with clips and whatever bracket(s) are necessary and will obviously be cheaper the more people want to go ahead with it, but for now, if you are interested feel free to say so :blink:
https://www.sau.com.au/forums/topic/311501-m35-brake-fluid-panel-cover/
  • Replies 122
is be interested. but would want to have a look at fitment first.
Of course, not after deposits at the moment, just an eoi
I will only offer a kit that is ready to clip straight in :blink:
Edited by iamhe77
Very bloody interested!
By the way Cam, I modified the catch can by cutting a hole in the top, threading it and fitting a knurled cap with o ring. Now I can run the stainless scourers inside it. I am making a bracket to hold it in too if you want one.(instead of the cable ties)
LOL... yeah wouldn't mind. Will save me a bit of time this weekend making one up (cable ties were temporary :D )
Scourer? again?? Why not take the top off (unscrews I am told) and add a divider down the middle to force the air down and around? Maybe better, yes?
They are definitely threaded but I couldnt budge it. Now I have a fancy knurled cap. :D
I was going to make an alloy sheet brake unit cover and paint it black but this idea sounds much better, just hope it fits ok.
For those interested, here are a couple of pics with the cover fitted (no brackets as yet).
Price will be $145 which includes cutting to the cover and shipping to your door.
If interested you should not that there is some cutting of the existing bodywork that is necessary to fit it.
Need a minimum of 5 orders and will require payment up front :)
Edited by iamhe77
It would appear I need slightly more than the Break Fluid panel cover.. I thought there was meant to be something covering that corner :(
Spose getting a battery cover would now just look a bit silly too! Ah well.
  • 2 years later...
I am getting a bit sick of having a nice battery cover one one side of the engine bay while there is a gaping hole on the other side which has nothing but uglies on display (plus I'd like to hide the catch can smile.gif)
Now, I figure I can't be the only one that thinks this way (although it is a common occurrence tongue.gif) so depending on how many people (if any) would be interested and how much needs to be done to fit it, I will look into a group buy in the not-too-distant future.
Cost will be a maximum of $160 delivered to your door with clips and whatever bracket(s) are necessary and will obviously be cheaper the more people want to go ahead with it, but for now, if you are interested feel free to say so happy.gif
Has anyone managed to persue this? what's the part no? I would be interested on 1.
I found one supplier on eBay US for around aud$80 delivered so a group buy should lesson the postage making them slightly cheaper again.
How many people would be interested on this group buy? 1 will have to be send to chc nz.
I can get 10 sets sent to me, but I can't ship them to people for that. Feel free to post the link.
IF you guys are interested in a GB, I would need a minimum order of 10 and the cost of each will be $92 shipped to your door.
