Anyone Townsville ppl here?
CalaisT3RBO
 Share
Hay All
Just have a Q's for    GTR13    , you said you only trust Gavin Woods with your car
I have a 95 gtst on it's way over from Jap , it is stock and I am looking for a good bloke to put a couple of go fast bit's on , not looking for a 10 sec monster , do you think Gavin might be able to help me out as the car will be in bris in about 4 weeks , and if so could I get his # pls
Houdy All,
My mate just got his 33 GTR V-spec and his 33 GTS-t tuned and serviced by Gavin Wood. He was very impressed.
Gavin Wood Auto Tech
1/23 Gibbs Street, LABRADOR. 4215
Ph: (07) 5529 2313
Have fun!!
Haro
[email protected]
  • Replies 55
Hay All
Yep Gavin is an excellent tuner i would book it in as soon as you can as he gets very busy . I would not go to any of the so called performance workshop up here they are hopeless!
Also Gavin is in Labrador as you come into the gold coast not in brisbane i think Haro has all the correct details.
AFAIK we still do not have 98 RON fuel. Closest is Rockhampton with Optimax. BP up here is suppose to be getting ultimate but we will wait and see.
Gavin Wood is very good, I took my car to him 2 days after I picked it up and was very happy.
Does anyone go Jet Skiing in Townsville?
Hey guys saves me making a new thread.
this is deffinent this time were coming down on the 13th march for the street meet at the townsville drags.
so hope to see use all their and racing..... were bringing a couple of skylines down and some silvias.
hope to see some more skylines down their and some gtr's aswell :D
Cheers,
Cameron
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
