Hey guys, got a few parts left over from the R33 wreck. Pickup in Sydney or I can post!
Tein Control Master Flex coilovers, suit R33 Gts-t - $1000 ono
Starcorp 19" 114.3x5 & 120x5 Wheels & tyres - $1600 ono
Tyres are nearly new, and theyre good quality!
Fronts are 19x8.5" +38 with 235/35 Federal SS-595 tyres @ 90%
Rears are 19x9.5" +45 with 265/30 Federal SS-595 tyres @ 98%
Tomei 256 in/ex poncams, 8.5 lift. Suits late S2 r33 rb25 Skylines (black CAS) - $650
Exedy HD button clutch, not that much use, plenty of life left - $250 ono
Lightened Flywheel, unsure of brand. weighs appox 6-7kg - PM me if ya need the exact weight! - $200 ono
Recently machined.
Nismo clear indicators, suit R33 skylines - $50 posted
PM me if youre interested in anything!
Pms replied
Coilovers are height and damper adjustable, and I weighed the flywheel - 4.9kg - about half the weight of a stock one
  • 4 weeks later...
yeah sorry, it's a push clutch to suit R33 gts-t etc. Think theyre good for around 250kw?
that will hold plenty more than 250
GL
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
