What's wrong with using the standard latch with a bit of steel cable with a D shackle at one end and a carabina at the other end as a secondary (or tertiary...) bonnet restraint? :cheers:
What's wrong with using the standard latch with a bit of steel cable with a D shackle at one end and a carabina at the other end as a secondary (or tertiary...) bonnet restraint? :laugh:
Not everyone is as ghetto as you Matty. :cheers:
car mate sells and installs them, or try www.vsport.com.au they have the proper ones on there not the cheap chinese ones that break after a week of having them on the car like my ones did :-/ i will be buying the ones off vsport.com for my car.... they even have carbon fibre ones lol
its for a c/f bonnet matt not for cams rules.
I would not be running a c/f or fibreglass bonnet without bonnet pins of some sort, and the aerocatch ones don't protrude from the bonnet which might keep the cops happier (not that a c/f bonnet is legal itself lol). down side of the aerocatch ones is they don't really fit properly after a bit of use - so probably ok on a road car where the bonnet doesnt open often but a PITA for a race car where it opens all the time
Not everyone is as ghetto as you Matty. :)
What can I say, it's the drifter / R31 owner in me. If the solution costs over $50 then it isn't worth going for :nyaanyaa:
c/f and / or FRP bonnets don't come with provisions for a standard latch? Learn something new :nyaanyaa:
They do come with standard latching point, most people prefer to have extra restraint at the edges as at speed the more flexible CF bonnet can lift up at thefront corners and in extreme cases this leads to broken latchs and bonnets on windscreens...
To the op, get aerocatch flush mounting latches from vsport.com.au and get Greg at Autosport engineering in kirrawee to install them. I did and was very happy with his work, as I always am.
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
