Hey Guys,
My mate's mech told him his upper control arm bushes on his 33 are shot.
Now he has been quoted around 2.5hrs labour to do both sides and around 200 in parts. i found this kit from whiteline KCA348 at 192.80.
My mate is broke atm and i know bugger all about these and just wanted to check whether
a) the whiteline stuff is the go?
b) is the 2.5hrs labour about right? is this something you can do yourself? apparantly the bushes have to be pressed in by machine?
cheers in advance Rich
https://www.sau.com.au/forums/topic/311626-r33-upper-control-arm-bushes/
those are the outer bushes, are they the ones that are shot? there are inner bushes as well...
http://203.31.191.243/fulcrumCat/
ive done it a couple of times dyi, its a pain. you could use a g clamp etc, but we used some large washers to compress the bush into place.
Interesting topic, im in a similar situation myself,
What is involved in getting to the bushes, do I need to take the control arm off.
When you put this all back in do you have to adjust the camber or anything like that.
Can anyone give me a run down on this.
Also 180 2 Envy do you have any pictures of your car, I would like to see if I am indeed envious of your automobile.
its a simple enough job, just some work involved.
car up in the air on stands
wheel off
undo the outer and inner end bolts for the control arm to remove it (can be siezed on pretty tight so maybe get some wd40 on them then come back later)
press out the old bushes (hard to do it without a big press, I broke a little mobile press doing UCA bushes)
grease then press in the new bushes
reinstall the upper arm, tighten bolts to spec (pretty damn tight, check the workshop manual)
wheel back on
car back on ground
tighten wheelnuts to 110nm
drive to wheel alignment
assuming the bushes are not adjustable you will have not problems driving to a wheel alignment. if they are adjustable be careful, random wheel alignment can lead to very unpredictable handling (camber affects toe as well). try and set adjustable bushes at home first to same time and money at the wheel aligner..shorter distance between inner and outer bolts = more camber.
wheel off
wheel back on
car back on ground
Cheers for that Duncan, that helps a lot.
Edited by mikeyG
the 33 upper outer arm has a pin/bolt the whole way through, so take the nut off the end and knock the pin through. then prise the arm off the upright.
prise the one end of the bush off, flat head screw driver between the upright and the bush. once you have 2-4mm, some needle nose pliers, open
em up and wrap them around the bush. then push back and forward until you have the bush off. then you can access the bush on the other side
from the center to knock it out.
you can do all that with the arm still on the car, as the bush is in the up right (its quite different to the 32 arm) .
grab the new bush, knock one side in. put the bolt back on (this is if you have split bolt with the new bush) with the largest washer you can
get from bunnings etc, tighten it up a bit.
knock the bush in the other side and do the same. tighten em up, then take the washer out and put the arm back on.
  • Like 1
Hey guys, thanks for the info - i have passed it on. he will give dyi a go as his dad can get the bushes presed in at his work.
Hey MikeyG i should change my username as the 180 is long gone and it never got to an envious stage unfortunately it was a project started but never finished(not even close).
cheers rich
Most excellent info mate!!
Did the removal just an hour ago and it was very easy. I only used a flat head screw driver and a hammer and it was done in about 10 minutes on one side! Time here is now 00:22, so I'm going to bed.
Will do the other side and install the new super pro bushes with camber correction tomorrow.
Many thanx!
BR, Stefan
  • 3 months later...
im in the same boat, well, im getting a slight nocking noise comming from the rear drivers side while at 20-30km/h or so, got told it was prob a bush that was stuck and causing excess movement. only thing is bushes seem to be fricken expensive. what bushes are needed for a standard r33? although mine has a 1.5 diff in it that really shuds ya round corners. is there any dangerous problems from driving on warn bushes if thats my case? i have a trip i have to make on the weekend is all
Edited by buckets
  • 1 month later...
I thought this was the case on my r33, when i sprayed a lubrication at the inner bushes on the control arm, it would stop making noises, i bought a second hand one and had it replaced, but just for shits and giggles we pressed the old bush out of the arm, and made an absolute mess of the bush, but could not find any replacement bushes that were made for that part of the arm. After a month the clunking noise came back so i thought the second hand one was stuffed, so i bought two new upper control arms for $570 from nissan, same thing again, it was all good until i drove over a cattle grid halfway to brisbane. Turns out the clunking noise was just a Stabilizer Link Pin and was shot inside cost $100 to repair.
As for the fulcrum bushes, i replaced the outside bush with the adjustable camber ones from fulcrum, and now it is done up that tight it squeaks every bump driveway, and i still have a large camber. So i will need to get this fixed.
What sort of bushes can i replace the outside bushes with. Was thinking polyurethane again, and would they have to be adjustable ones, even if they come in some sort of kit, i may consider buying this way. What's a different fairly good brand i could replace with?
Cheers.
Edited by 3340TH
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
