Hi guys,
For sale is my Innovate LC-1.
I purchased this with the intention to fit it to my Skyline but I have never got the chance. I did try and get it working but ran out of patience. There are plenty of people using them, so I think it is probably my incompetence!
I bought the unit second hand but I have not used the unit since I have owned it.
I have wired it into a cigarette lighter plug for easy installation.
Includes the following:
Wideband O2 sensor
LC-1 module
Software
Weld-in Exhaust bung
I also purchased an additional USB to Serial Port adapter.
Here is the official info page for the LC-1:
http://www.innovatemotorsports.com/products/lc1.php
I am chasing $200 for the Innovate. I will post up pictures over the weekend.
Any questions, PM me!
Chris
https://www.sau.com.au/forums/topic/311658-innovate-lc-1/
  • 1 month later...
  • 3 weeks later...
    • Ohh even easier.   Go dial up 700rpm on the hand controller. Rip off the TPS plug, wait till the idle drops and then adjust the IACV screw so it's just a tad below the target on the hand controller (say 650rpm), plug the TPS back in and idle will climb back to target. Done.
    • Hey Sleepergm, I love your inlet piping, do u mind sharing who did the work, please? cheers, Ian
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
