Hey Guys,
Thinking about converting to a top-feed injector setup, to open up alot of options for me. Just wondering if anyone has done it, what the pitfalls and traps are. How easy was it, costs involved etc.
I've done a search, but just cant find an answer.
Thanks
fuel RAILS on the other hand... I'm yet to find a single aftermarket side feed option... not even a cheap copy is available! :laugh:
If I could swap my 850cc side feeds for top feeds, I would in a heartbeat... I'm miffed I didn't do more research...
I can see the appeal of top feed injectors - bosch's latest range of high impeadance EV14 injectors are available upto 1000cc/min twin spray. Bet they would tune great to. It seems that top feed is the what all manufactures are going to if not Direct injection.
what power are you making? im yet to max out the std rail on pump.
I was at 350rwkw on E85 with the standard rail. Only changed rail to go bigger 14mm injectors.
To the OP, no need to go top feed unless you are chasing BIG power.
If only Nismo made a 1600cc injector lol The 740s i had were the best injectors i have ever used.
  • 1 year later...
Sorry to revive an old one, but im interested in getting a top feed setup on my R33. Main reason is because I want to get ID 725cc's. They are alot cheaper then any other type, eg SARD, NISMO.
I run a standard intake plenum. Would I be able to buy eg, an R34 GTT rail and use that or do I need to modify anything else?
Cheers guys.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
