http://www.boostcruising.com/forums/index....howtopic=538484 PICS
Item Summary: BMW 318IS 2door coupe,Manual,lowered,black m3 rims,new paint job VERY VERY IMMACULATE!! HEAD TURNER!!! MUS SELLT/SWAPS
Condition: Used
Reason for Selling: Want a change -
Asking Price: 9900
Delivery Methods: PickUp
Contact Info: 0421 878 209 sms/call anytime
Extra Information:
93 BMW 318IS E36
2 D00R
MANUAL
NEW PAINT JOB
NO DINTS SCRATCHES ITS IMMAC
GLOSS BLACK BONNET
PIONEER CD PLAYER
SONY SPLITS
PWR STEER
A/C
PWR WINDOWS
200XXXKS
MATT BLACK M3 WHEELS - NOT SHOWN IN PICS!
LOWERED ON JUMBOZ SPRINGS
LIPPED GUARDS
TINTED
(20S NOT INCLUDED, BUT CAN SELL FOR EXTRA $800)
ALWAYS GARAGED
ALWAYS SERVICED ON TIME
NO OIL LEAKS
RUNS VERY VERY SMOOTH
INTERIOR IS IMMACULATE AND CLEAN..SPOTLESS NEARLY!AS NEW.
WILL SWAP FOR A NICE 200SX S14A OR 180/15 OR GTIR,WRX,R32,R33 ETC.
  • 1 month later...
    • Does anyone know what the centreline should be for the vct intake cam? On my cam spec card it just says VARI and doesn’t actually tell me what the centreline should be. I had to adjust my exhaust cam gear by about 5 degrees advanced so I’m guessing I would have to adjust my intake as well? Current intake centreline is 119 deg. Iv already asked kelford and they won’t respond, It’s the 246-A 262 cams.  thanks for the help guys
    • Get a timing light on it and verify it's sparking reliably at a sane ignition timing. Use a COP extension lead to be 100% sure about timing instead of hoping that the timing loop on the back of the engine is accurate. Make sure it's actually injecting fuel. MAF is not used on the stock ECUs for initial cranking.
    • RE5R01A is the transmission. Didn't realize they had a 5 speed for the NA cars but for some reason the turbo engines stuck to 4 speeds. Looks like the solenoid block is still available from Nissan directly at a somewhat reasonable price: 31940-60X01 https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er33/6568-rb25de/trans/317 I would move sooner on this than later. The moment the de minimis exception for Japan goes away expect to be paying 25% tariffs even for stuff like this.
    • Only RB26 are low from factory. And even then the ECU actually want high impedance, because it's essentially the same ECU as the RB20 anyway, and thus they have a f**king resistor pack!
    • Is this preventable by priming the system with external oil pressure? I've seen the speed academy folks hook up an external oil priming system to the oil pressure sensor port with an air compressor to check for oil leaks before putting an engine back in a car. Something like this: https://www.jegs.com/i/JEGS/555/23550/10002/-1?gPromoCode=SPRINGINTOSPEED_APR25_5Off&gQT=1
