Hi everyone,
As I understand it... all R32's and the series 1 R33 and R33 GTR's use the same type of coil pack, which uses an ignitor module to fire the coils. And the series 2 R33's and all R34's use a coil pack that has a built in ignitor.
Now here's the question.... Are the plugs for the series 1 and series 2 coil packs the same?
The reason I ask is that I need to source a coil pack loom so I can cannibalise the plugs off it for a custom wire up that is using R34 GTR coil packs. I’d rather not buy a genuine coil pack loom only to chop it up for my project.
Cheers,
Ian
do you mean ECR33 series 1 & 2?
if so, then the plugs are physically different
and ER34 has different style of plug again
ie you cant use ECR33 series 2 coilpacks on ER34
So you mean there is 3 different types of coil packs then?
I only have R34 gtr coil packs in my posession. So these would be the same as series 2 ECR33 then I presume because im pretty sure they also use the SPF-005 coil packs...?
Edited by GTRNUR
Well that rules out R34 GTT looms. I was more interested in R32's and Series 1 R33 looms/coil packs though, as these are far more common and I can probably find a wreck a lot easier to pinch the plugs from if they are compatible.
If anyone has a photo of an R32/series 1 coil pack and can post it up it will be helpful.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
