Hi all i have a 1995 series 1 gtst. Was at the drags not long ago and found out that only one of my wheels spun while doing the burn out :blush: . I thought all of these cars had lsd in them??? Does mine have one and just doesnt work?? How can i tell? If its not one can i just buy a replacment one and just bolt straight in or does it need more then that?? Thanks.
https://www.sau.com.au/forums/topic/311732-lsd-problems/
yeah pretty much all of the factory nissan LSDs stop working after about 50,000klm, they just become SDs :(
depends how much of a problem it is for you - a new mechanical diff is about 1500 installed but will last much longer. no point buying a second hand LSD it won't work either
https://www.sau.com.au/forums/topic/311732-lsd-problems/#findComment-5130950
yeah pretty much all of the factory nissan LSDs stop working after about 50,000klm, they just become SDs :)
Am i able to get rebuild kits for the standard one or not worth it???
https://www.sau.com.au/forums/topic/311732-lsd-problems/#findComment-5134359
You can shim the standard viscous centre to improve its performance (there's a thread on how to do it in the DIY section). In my opinion it's not really worth it, as it will wear out again and be open wheeling in no time. If you're going to pull the diff apart to shim the centre, you may as well replace the centre with a better one. So I guess in order of expense you have 4 options:
1. Shim your current centre, cost $50.
2. Replace the centre with a Helical (Torsen) centre out of a turbo S15. This is what I have done in my car... I have written a thread on how to do it (and the benefits) in this forum. You will need an S15 diff and half shafts - it cost me $250.
3. Replace your diff centre, half shafts, and hubs with the same from a R32 GTR. If you can get these at a good price, it is a very good option as the R32 GTR diff is mechanical and has stronger half shafts. Though expect to pay between $500 - $1000 for all you need.
4. Replace your centre with an aftermarket 1.5 or 2 way Mechanical. Expect to pay upwards of $1000 (new).
As I said I went for the 2nd option. I'm very happy with the diff, it has a gear type centre that will never wear out, and by design the diff equalises torque between the rear wheels - So when you go round a corner, the outside wheel (which is rotating faster) gets more power applied to it, to equalise the torque with the inner wheel. This makes for a very good diff for street and circuit driving, as it helps drive the back end of the car around the corner. Options 3 and 4 are better if you're into drifting.
Hope that helps, Ryno
Edited by Ryno
https://www.sau.com.au/forums/topic/311732-lsd-problems/#findComment-5135079
Thanks heaps for that mate helped heaps think ill go number 2 aswell.. Thanks again...
https://www.sau.com.au/forums/topic/311732-lsd-problems/#findComment-5139745
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
