hey guys im selling my spare rb26 from my second r32 gtr which was imported just as a parts car for my better gtr to get those hard to get genuine smaller items... selling to try and free up some shed space , info below
r32 rb26 engine 100% complete as removed from the car with all accesories (other than a/c compressor) and bolt ons but no clutch or flywheel
all electronics included such as afm's coils ignitor cas ecu loom etc etc
nismo ball bearing turbos
the engine runs very VERY well blows no smoke no rattles and was very very quick
oil was changed and flushed prior to removal for better/longer storage capability engine has been turned over by hand every few weeks to keep everything sweet
currently the engine has a blown head gasket between cylinders 2 and 3 not into water or oil at all but you would never know i just found this when i did a routine compression and leak down test prior to removal from the car it was in ,from memory the other cylinders were within spec also, to me this is not an issue because whenever i install a engine i usually like to use a steel head gasket straight up , so its not like its a real problem
several members from this forum have seen the engine running it runs quiet and 100% smooth and "normal" with no issues it diddnt have a missfire at all and diddnt even show any signs of a blown head gasket what so ever... ran perfectly fine and drove awesome under load and it would have smashed my v spec gtr easilly
price for engine ecu loom afms accesories and bolt ons as a complete bolt in turn key package including the nismo ball bearing turbos $4800
any other questions just hit me up and ill answer as best as i can , any pre purchase inspection within reason is fine by me as long as you prove to me you are serious and have the cash
r32 gtr gearbox and other r32 gtr parts available upon request
located 1 hour west of Brisbane
cheers
Edited by WHITE R32
https://www.sau.com.au/forums/topic/311740-complete-r32-rb26-engine-package/
  • Replies 73
may seperate accesories and loom ecu etc for someone who just needs an engine.... but pm your offer and list of what you do and do not want
i will not even consider selling small items untill the bulk has been sold
i am unsure on specifications all i know is that when the car was purchased it was told that it had nismo turbos and these turbos do have the little rectangle cast into the compressor covers like the nismo turbos you see all around the net
comp covers like these below.... normal factory plain bearing turbos do not have this afaik
another example
it was a little laggy but it went like stink when it came on at 1 bar of boost :)
Edited by WHITE R32
$3990
Still interested in the whole package.
I will have to upgrade the crank collor to put the whole package into a GTR33 ( recovering a Racepace motorsport gun engine with 400kwrw to put into my track car )pm me or call me on 0433 878905 to discuss further.
Alex
ww.jds-auto-imports.com
mayyyyy consider selling turbos seperate but id have to find out exactly which ones they are somehow first
tim/alex... if you are interested pm me back as im not sure what youre on about there??
hey mate... check the serial numbers on the core.. there should be a little metal tag.. saying what the product number is..... and then post it up on here, there are plenty of ppl on this site that can tell u what they are from those numbers..
yeah from what i can see thus far there are no tags otherwise id have posted them up already
the car was reasonably laggy compared to a std one and when it hit at 1 bar boost it hit bloody hard which made me look into it which was when i discovered the compressor covers which resemble the bb/nismo versions but as far as exact model type i dont think id know untill i relove and measure them up which i dont really want to do unless the engine or the turbos have been sold... rather keep it complete and in the one place with no small parts missing
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
