you mentioned other GTR bits: shoot me your number I have to make a run up there anyway so I can pop past and see you.
  • Replies 73
gearbox still available?
I'm chasing a 32 or 33 gtr box, for 6 speed conversion into my gtst.
yes i know what to do to convert to gtr box lol
if you're selling it how much? PM me
I'm located in Toowoomba as well so I imagine you'd be close to where I am.
Cheers
Edited by fattox33
Cheers
only the 34 had a 6 speed box!
issues like what?? it all depends what you are capable of as to what constitutes it bieng an issue i guess... for me doing it there are no issues as the rb26 also came in r34 gtr's
main issue would be wiring but i know a guy who can do that quite easilly for a good price and the sump which you can buy off the shelf from high energy now i believe
here are some pics of the turbos...
the compressor wheel size with the vernias seems to be around 47mm but hard to say exactly on such a weird angle
a guy from MTQ turbos came and looked at them on the engine and said they are definatly not factory nissan turbos and they appear to be ball bearing also
factory compressor cover is .42 but these are .6 and seem reasonably large by comparison
also included to pics of the std ones to compare
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
