Have an rb25 in my r32 & recently installed a Haltech ECU & got a tune.
The day after my tune I discovered a hose had come off an intercooler pipe (probably during tune) so I have re-attached that & am fixing up a few little things then I will go for another tune.
Anyway for the last few days when I go to start my car (just to move it around, etc.) as soon as I turn the key to ignition there is a bang from the exhaust, almost like a little backfire... But the engine isn't actually running...
Have never really had or heard about this before & I'm getting really curious as to what it could be
If anyone has experienced this or has any ideas please let me know...
https://www.sau.com.au/forums/topic/311753-backfirepop-when-ignition-turned-on/
I'd bet the columns for 0RPM in the tuning map have values in them that aren't 0 and the ECU is pulsing ignition and fuel as mention.
Most ECU's still need to see a crank reference (bare minimum) to pulse the injectors and coils - shouldn't matter if you have values in the 0rpm column.
Hope its not CAS. Never had the issue before the haltech went in & was tuned so does that rule that out?
Leaking injector(s) is something I will try to look into, & is quite possible as injectors were recently highflowed. Will also check 0 rpm tables on haltech & cranking rpm too.. Should mention it doesn't happen every time..
Whatever it is I'm guessing it wont cause any major probs?
For it to pop out the exhaust there needs to be spark. If the issue was not there b4 the haltech went in - then it must be the haltech. Seen it b4 and there is nothing really to be alarmed with as long as the car drives fine.
It also needs fuel, spark alone will not fire a cylinder. Also you say it doesn't happen every time, that is because the spark happens each time, but the firing order means that the cylinder with the fuel only lines up randomly with the spark every now and then.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
