:(list of some parts and standard items i wish to sell from build-up :worship:
- standard radiator from s2 R33 RB25DET excellent condition $150 SOLD
- standard s2 R33 RB25DET block no head, block is in excellent condition, $800 SOLD
- Gizzmo IBC Electronic Boost Controller excellent condition comes with everything $250
- standard in-tank fuel pump s2 R33 very good condition $50 SOLD
- s2 R33 RB25DET auto-trans + pedals excellent condition stage 2 shift kit been serviced new filter trans-fluid etc from mike at M.V. automatics $500ono
- s2 R33 RB25DET impul auto ecu removes speed limit cut rev limiter goes to 7.200rpm i think been awhile since i have been on the dyno give or take boost cut removed or moved i was running 14.3psi excellent condition $200
- 2x standard boost solenoids good condition $15 each
- s2 R33 whole complete A/C from the engine bay ill check with my mechanic excellent condition $400ono
1 x Brand New Blue Castor Rod Bushes noltec or nolethane $65 pick-up or $70 posted.
1 x complete set off standard R33 s2 brake lines front + rear used but in fine condition no splits kinks etc $50 pick-up or $55 posted.
2 x standard R33 rims good for drifting etc camber wear on tread $70 pick-up only.
measurements in INCHES for thermal flex left overs...
1 x Thermal Flex (RED) 8" long X 2" wide------------------------ $15
1 X Thermal Flex (BLUE) 6" 1/2" long X 2" 1/2" wide------------ $15 ------------$60 for all 3 pick-up or $65 posted
1 x Thermal Flex (BLUE) 13" Long x 3" Wide--------------------- $30
1 x i believe its the heater unit minus the heater core $60 pick up or $70 posted.
1 x i got this from a group buy a while back black faced 300km/h speedo set in psi no 300km/h tho i have it in my car but i put the 180km/h speedo with the set, boost gauge on tachometer is in psi and oil pressure is in psi as-well + new hot/cold gauge and fuel level so everything except the 180km/h is new the set cost me $100 + postage so i guess it would be fair to ask for $50 pick-up or $55 posted.
1 x 1996 s2 R33 rb25det Throttle body good condition $60 pick-up or $65 posted
1 x R33 Skyline Standard Genuine Nissan Dump Pipe $30 pick-up or $35 posted
1 x R33 s2 Skyline nissan genuine rubber intake pipe used, good condition no perishing, comes with stock BOV plumb back hose $50 pick-up or $55 posted
1 x s2 R33 Cross Over pipe with b.o.v. $55 pick-up or $60 posted
1 x R33 s2 Original Nissan intake manifold (plenum) comes with top and bottom half rubbers, bolts, everything needed to fit it up., no cracks or leaks, reason for sale is put greddy intake on. $75 pick-up
6 x s2 R33 GTST 370cc injectors, all working when taken out of car, just been removed for nismo injectors these have only just been taken out and are all in 100% working and flowing condition!! comes with rail. $150 pick-up or $155 posted.
most items can be posted some cant...
contact me on here or e-mail me at (allan-5000@hotmail.com) or call me on (0401409575Allan)
i will start uploading some pictures tonight if i have got some time..
All items located in : Adelaide,SA
Contact me on (0401409575 Allan) or pm-me parts can be delivered via freight/courier at your expense or pick up in Adelaide,SA parts are with my mechanic so can organize it any-time.
most prices are negotiable.!
Regards.
Allan.M
1 x R33 s2 Skyline nissan genuine rubber intake pipe used, good condition no perishing, comes with stock BOV plumb back hose $50 pick-up or $55 postedSOLD
1 X Thermal Flex (BLUE) 6" 1/2" long X 2" 1/2" wide------------ $15 ------------$60 for all 3 pick-up or $65 posted SOLD
- s2 R33 RB25DET impul auto ecu removes speed limit cut rev limiter goes to 7.200rpm i think been awhile since i have been on the dyno give or take boost cut removed or moved i was running 14.3psi excellent condition $200 SOLD
back up for sale due to time waster
  • 3 weeks later...
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
