why the downgrade?
well if you built a 13b and squice 412 hp to the wheels, and on the last dino pull it blows up, and the apex seal takes your $1500 turbo on the way out. you will think twice to do it again don you think...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131816
Yeah, RB26's usually do it the other way around... Blow the turbo and take the motor out...
What is the car being used for? As the RB26 will be alot heavier up front destroying a fair bit of weight distribution in the RX7...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131821
Nice work mate - Be sure to let us know how it goes.
lol, don't hold back duncan
thanks man. it is fun, but the problem is that i don't now what chassis this engine came out of "i now is not a r34 lol" and the info in the US is very little. wiring harness is a must.. haw can i determine this out?
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131826
Drifting. and yes i pushed it as far an low as possible.
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131831
I was meaning weight overall.
The RB26 has to be at least double, if not triple the weight a 13B.
Might help though with drifting, more front end grip. Circuit racing would be a different story though.
Have you weighed both motors up at all?
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131837
i think is 175 to 200 and im taking a tone of wires, bumper support, dash stuff that dont need
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131846
Surely though a 300rwkw rotor shouldn't just "die" if built right?
Few friends of mine have had reasonable powered rotaries without much of a drama.
What about SR20? That idea cross your minds? Would be lighter and then less need for more power :nyaanyaa:
lol that :nyaanyaa:
If using the stockers of course... Which i pray he isn't...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131855
Is that a comment based on myth or fact? :nyaanyaa:
As i said, i know a fair few rotor owners... it's nowhere near as bad as everyone "thinks" which is just based on rumour among the piston crew predominately.
Add to the fact rotor rebuilds are nothing of the expense that is a RB26.
I've heard of more RB26's letting go than rotaries among all the people i know... which is an interesting thing i think :nyaanyaa:
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131875
lol that :nyaanyaa:
the point is that it "happened" and now im up to better and grater things. live alone challenging, there for sr20 is out of the question, its bean done numerous times. and a FC/RB26 not that i now of...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131886
Same here... And that's if you EXCLUDE Duncan from that list...
PS: I hope you've fitted a winged and gated sump to that thing... Other wise I see it lasting around 1 drift meet...
When treated right, a Rotary will last well into the 200 000KM range. (Which is the same for most performance motors, yes your mums Dad's Uncle may have a commodore that has 450 000KM on it, but does it get revved to redline every day... No)
Edit: And by the sounds of it letting go... Sounds like it pinged... And that is one thing a rotary will instantly shit itself from... Detonation.
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131895
yep it was mi mistake. forgot to wrap the down pipe and premix so it was catastrophic failure. the back iron broke were all do... and the center one pushed the coolant seal into the passage. + the rotor and rotor housing and turbo GT35R lol im done with them for now.
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131917
Yeah but wouldn't this be because people (making an assumption) think that rb's can take a beating... and they know for fact! that a rotary will be more fragile under load hence why the 26's are blowing quicker in most cases because the driver will take more caution with the rotary and give the rb the beating of its lifetime lol
you get what I'm saying?
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131921
Have you seen rotary guys giving it a go? I have... They push just as hard as piston drivers do...
And the OP admitted his one letting go was a human error issue, not a mechanical flaw...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131925
Yeah fair enough :nyaanyaa:
Although it's not the first RB26 into a FD :nyaanyaa:
One... if not two of the big Jap tune houses have a FD with a 26 (or at least had one hehe)
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131926
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
