why the downgrade?
well if you built a 13b and squice 412 hp to the wheels, and on the last dino pull it blows up, and the apex seal takes your $1500 turbo on the way out. you will think twice to do it again don you think...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131816
Yeah, RB26's usually do it the other way around... Blow the turbo and take the motor out...
What is the car being used for? As the RB26 will be alot heavier up front destroying a fair bit of weight distribution in the RX7...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131821
Nice work mate - Be sure to let us know how it goes.
lol, don't hold back duncan
thanks man. it is fun, but the problem is that i don't now what chassis this engine came out of "i now is not a r34 lol" and the info in the US is very little. wiring harness is a must.. haw can i determine this out?
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131826
Drifting. and yes i pushed it as far an low as possible.
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131831
I was meaning weight overall.
The RB26 has to be at least double, if not triple the weight a 13B.
Might help though with drifting, more front end grip. Circuit racing would be a different story though.
Have you weighed both motors up at all?
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131837
i think is 175 to 200 and im taking a tone of wires, bumper support, dash stuff that dont need
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131846
Surely though a 300rwkw rotor shouldn't just "die" if built right?
Few friends of mine have had reasonable powered rotaries without much of a drama.
What about SR20? That idea cross your minds? Would be lighter and then less need for more power :nyaanyaa:
lol that :nyaanyaa:
If using the stockers of course... Which i pray he isn't...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131855
Is that a comment based on myth or fact? :nyaanyaa:
As i said, i know a fair few rotor owners... it's nowhere near as bad as everyone "thinks" which is just based on rumour among the piston crew predominately.
Add to the fact rotor rebuilds are nothing of the expense that is a RB26.
I've heard of more RB26's letting go than rotaries among all the people i know... which is an interesting thing i think :nyaanyaa:
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131875
lol that :nyaanyaa:
the point is that it "happened" and now im up to better and grater things. live alone challenging, there for sr20 is out of the question, its bean done numerous times. and a FC/RB26 not that i now of...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131886
Same here... And that's if you EXCLUDE Duncan from that list...
PS: I hope you've fitted a winged and gated sump to that thing... Other wise I see it lasting around 1 drift meet...
When treated right, a Rotary will last well into the 200 000KM range. (Which is the same for most performance motors, yes your mums Dad's Uncle may have a commodore that has 450 000KM on it, but does it get revved to redline every day... No)
Edit: And by the sounds of it letting go... Sounds like it pinged... And that is one thing a rotary will instantly shit itself from... Detonation.
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131895
yep it was mi mistake. forgot to wrap the down pipe and premix so it was catastrophic failure. the back iron broke were all do... and the center one pushed the coolant seal into the passage. + the rotor and rotor housing and turbo GT35R lol im done with them for now.
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131917
Yeah but wouldn't this be because people (making an assumption) think that rb's can take a beating... and they know for fact! that a rotary will be more fragile under load hence why the 26's are blowing quicker in most cases because the driver will take more caution with the rotary and give the rb the beating of its lifetime lol
you get what I'm saying?
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131921
Have you seen rotary guys giving it a go? I have... They push just as hard as piston drivers do...
And the OP admitted his one letting go was a human error issue, not a mechanical flaw...
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131925
Yeah fair enough :nyaanyaa:
Although it's not the first RB26 into a FD :nyaanyaa:
One... if not two of the big Jap tune houses have a FD with a 26 (or at least had one hehe)
https://www.sau.com.au/forums/topic/311809-rb26-on-a-rx7/#findComment-5131926
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
