hi guys i installed a mechanical boost gauge yesterday so i could install a boost controller,
i was hoping that i could run a duel setup so i can run the standard boost then with the flick of a switch i could run 10psi, but after installing the gauge i took the car for a run and noticed its boosting at a constant 11psi !!!! not the standard 5psi.
so i opened the bonnet and looked every were to see if i could find a manual boost controller but there is none, my question is how could my car be running more boost without a boost controller, could it be modify ed or is there something possibly wrong ?
when i purchased the car they said it was stock but the turbo may have been a factory upgrade because the spool up sound is different to any they have had in ?
  • Replies 51
ive got a turbosmart dual stage boost controller for sale if you need it. 120 and its yours.
i never knew standard r34's to run 5 psi lol
isnt the reading in kpa?
so .5 kpa is 7psi... as i think 1 pound is 14 psi?
0.5KPA relative is 0.072PSi relative.
they run 5 psi up to 4500 then 7 psi to redline . it might have a r32 actuator on it . or most likely it had had the restrictor removed or drilled out . it the solenoid still plumbed in and wired in?
hi i had a look at the exhaust and i have 3" from the cat back and the cat and back pipe looks like its 2-2.5" ?? this is the best photo i could get with the bulky camera i have .
thanks again for your help people , sorry to start a debate about the standard psi im new to turbos and was told they run about 5psi standard! sorry my bad i was miss informed.
As someone said above, they run 5psi and switch to 7psi higher in the rev range.
That's the standard OP6 turbine housing you have there - compressor housing looks a little bit shiny but could just be nice and clean stock variant. I'd say your actuator has been fiddled with, or you have a leak in the vacuum line running to the actuator.
hey, sorry don't want to steal your thread mate but isn't the stock boost in an r34 gtt up round 11-12 psi? mine is running with no mods and the in car gauge is up there...
from what i have read on other posts its only ment to be 5psi then 7psi ???
unless thats for the r33? so im comfused as well because alot of people will tell you at 12psi your pushing your turbo to its limits and it may fail.
you maybe like me and posibly something has been done to it in japan by a previous owner.
I've seen 2/3 stock R34s on dynos around here and they all ran near 11psi with just exhaust - I don't recall even seeing any sign of dual boost levels, like the R33s have.... though its been a while. I do remember the ~11psi part (with no boost control) vividly though.
ok so should i replace the line ? how can i tell it it has a leak ? would it be louder at spool up ?
No harm in replacing it, it's only vacuum hose - very cheap stuff and easy to replace. You can use leak detector spray?
Yes you can hear a vacuum leak sometimes, which you may mistake for a spooling sound...however it is more than likely louder because you are running 11psi instead of 7psi. Now that people are mentioning it, perhaps R34 do run 11psi standard? They have about 20kw more than the R33 RB25 but I always put that down to the variable valve timing.
Yup mine boosts to between 0.6-0.7 on the standard guage. On a dyno it shows a constant 9psi without any boost control mods at all.
do you have any exhaust mods? that might be the difference? just guessing tho
34's dont run the solenoid like 33's AFAIK
The 34's I have driven have only ever boosted to about .6 max - with no sign of a switch from 5-7psi...
They definitely have a solenoid; You can both see on the gauge and feel the power change on my R34 at 4500rpm (in the wet, I've had it cause the rear end to slide out as the boost increased at 4500rpm).
With a 3" turbo-back exhaust and k&n panel filter, mine will do 0.5bar (7psi) up till 4500rpm, then 0.6bar (8.7psi) to redline according to the MFD.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
