6x9 don't fit in the front, despite all my effors. Put 6.5" in front on mine. Mange to fit 7x10 in the back on mdf, with out modifiying the parcel tray. It just clears the window.
Yeah make all your mounts on MDF, cus it won work other wise. Well depends how much metal u might want to cut in some instances.
  • 3 weeks later...
  • 1 month later...
I've just tried to fit 6.5" speakers to the front doors of my R32 and they won't fit behind the factory grille.
Are there any tricks I might have overlooked?
They are 62mm deep plus they need 14mm clearance in front to clear the suuound, 76mm total depth. There is 68mm between the window mechanism and the top edge of the factory grille so they are 8mm too big.
How deep are the 6.5" speakers that people on here have fitted successfully?
How are you mounting the speeaker? Are you just mounting thwem to the metal door? I would suggest using 18mm mdf as a backing board then putting the speaaker onto that. Dont worry about putting the speakers speaker grill on it.. not needed when it is being proteected by the door grill. Give that a try, you will find it will work. Heck, if i can fit a 4inch and a 5.25 inch in a 4inch speaker fitment, anything can be done.
Quote mtopxsecret6
"How are you mounting the speeaker? Are you just mounting thwem to the metal door? I would suggest using 18mm mdf as a backing board then putting the speaaker onto that. Dont worry about putting the speakers speaker grill on it.. not needed when it is being proteected by the door grill. Give that a try, you will find it will work. Heck, if i can fit a 4inch and a 5.25 inch in a 4inch speaker fitment, anything can be done."
Thanks for your reply.
I made a baffle and mounting ring to fiberglass at the correct angle with the speaker magnet as far back as possible but when I checked the clearances by refitting the door trim the top edge of the factory grille touched the speaker surround which needs 8mm of clearance during operation. The space is physically 8mm too small for this speaker to fity behind the factory grille.
Quote Fhrx
"The R32 skyline will happily take 6" speakers in the front doors."
Not my 160GTs but then they're 6.5s" I don't regret my choice of driver. I'll make it fit. Then again if I have to make a custom buildout I may as well fit my MW170s.
I just wanted to know how other people have approached this job in the R32s.
