  • Replies 67
  • 1 month later...
still got these
stock amber blinkers front and side - $40
factory boost hoses and intercooler pipe - make offer
series 1 front bumper - $150 ( has small scuffs but nothing a good polish wont fix, 1 small 30mm gutter scratch underneath )
batmbl (bos import) stainless front dump pipe , brand new never been used (selling for mate)- $330
pioneer 10' subs - $50 for both
manual stock computer only $40,000ks old (not pictured yet ) - $100
gtr foot pedals - $100 good condition
and 100 thousand service kit , brand new $280
Edited by nsm034
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
