  • Replies 67
  • 3 weeks later...
hei mate, can u please give me the dimension and weight of the dump front pipe? need to check the postage cost before any further negotiation
usually for this kind of stuff, postage is a biach!
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
Hey Buddy, where did u get the 100k service kit from and does it include everything needed for the 100k service for a R34 GTT?? Could you even post a pic of the 100k service kit..
Still have thebdump pipe? Whats the sizing
3 inch mate
got it from elite racing, got all you need for the 100k motor service
Edited by nsm034
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
