  • Replies 67
will take the foot pedals and timing service kit? call me or msg please 0403673876......does it come with water pump or just timing belt and seal kits?
yes has water pump aswell
Still got the dump? How much for postage to 3023 victoria.
Ken- 0435767585
not sure mate can send through the dimensions to you as it would be cheaper quotes on your end
Does the dump pipe have the connection for the O2 sensor? Can't see in the photo.
yes
  • 5 weeks later...
  • 4 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
