Well I got the usual foggy headlights that most series 1 R33's get and it now looks very noticable.
Pulling the headlamps out looks like a big job, I have washer bottle, cold airbox etc all in the way.
Whats the best way to clean them and stop it from happening again ?
Cheers.
https://www.sau.com.au/forums/topic/311860-foggy-headlights-on-r33/
cleaning them up is easy . polish it with anything . everyone will tell you anyhting from jif to tooth paste . meguairs do a plastic polish called plastx . it works well .
nothing will stop them turning yellow again tho .
Do you have to pull the whole light out, or can you crack off the lense cover ?
cheers
How quickly do they discolour again? Is it annoyingly soon after polishing, or do they stay clear for a useful while?
should last at least 12 months before they go cloudy again, but will take a few years for them to get the real ugly yellow
that's interesting...
I thought it was simply moisture on the inside surface of the plastic.
So the clouding must be caused by UV exposure.
Also,my car is garaged and has only been in rain twice in 6 months, and the fogginess is getting worse.
Thanks for the tips, I'll give it a go.
if it is a general cloudyness and discolouration then yes it is caused by UV. if it is just foggy and you can actually see water droplets inside then you have a leak and it is caused by moisture. post up a picture of your light so i can have a look.
I find Brasso works wonders (also awesome removing scratches from DVDs) - just don't get it on your paintwork!
that's why i went with the scratch-x. it is actually a product designed for use on paint so it doesn't matter if it splatters or anything like that. i would just put the woolen buffing bad on the drill, put some scratch-x on the pad, smear it round on the light so it didn't just fly off, then pull the trigger on the drill. took about 5 or 6 seconds per light of actual buffing to get them clear. it would actually take me longer to get all the gear out
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
