Rb20 Not Starting - Help Please
Only problem with that is it's obvious to the police, but same same with the aes valve. Most people get the valve precat so it's harder to see when looking under the car from the rear.
It's been a looooooong while since I did this, but... No, from memory there's a feed ring around the inside of the squirter. Otherwise, they would have to be too precise when machining the threads in the block, and the banjo bolts themselves.
