Hi guys.
i have an Axis Autec. its an 02 with cloth interior, no nav/screen.
reading a few of the older posts it refers to some of the differences etc between the RS-4 and the RX-4 and the ARX
going on Carsales there are some Axis cars badged incorrectly for example
this car advertised is clearly an Autec Axis but the wheels are missing.
Autech Axis - missing wheels
this car advertised is what you would consider an Autech Axis but is badged an ARX
ARX Autech Axis?
so i guess what im asking is did the NM35 Axis Autec come from a variety of different models or did they all start as a particular model ie, RS-4.
or could you take your Stagea no matter the model to Autech and have it modified to be an Axis.
its hard to distinguish as they all have different options etc. some with Sat Nav, some without, Some with elec Seats and some without, some with Leather some without. if you read the autech page listed in the M35 info sticky link it shows many different options.
https://www.sau.com.au/forums/topic/311905-nm35-autec-axis-rs-4-rx-4-arx/
Hi Garett
It is a little hard to give you a straight answer to this question as you can see by the cars listed it is a little confusing.
Most Autech Axis are from the RS/RX body and they are speced up but as you said, there are many different options that could be selected. The first car you listed is definitively an Axis with ARX wheels. As cars need to be complied as a factory car it is quite possible this car had non factory wheels when it was imported and they fitted wheels they had for compliance.
The second car you listed started life as and ARX (can be determined by the interior trim) and seems to have been optioned up with and Axis body kit.
I would say you could take any car to Autech and have it fitted with special options.
Cheers
Andy
I've never seen an Axis without leather before. What colour is the cloth interior?
it's black. With a suede like charcoal in the centres, black carpet. The car is pearl white which correct me if
I'm wrong only came on autech models
Im correcting you, Mine is the same. :(
If you want to know the factory specs I can run the Vin for you, will show if anything has been modified since.
can you get me a pic of the front wheel barring assembly? Just use your Vin otherwise I have to get off my lazy arse and go downstairs to the car park!!!
Andy tried but his is F$#king useless :(
Useless you say......... Who does not know their own VIN and still can not look up FAST??? :(:D
I think you will find my image was very accurate but perhaps you description of what you wanted was errrmm.."F$#king useless"... :(:(
Andy tried but his is F$#king useless :P
Useless you say......... Who does not know their own VIN and still can not look up FAST??? :D:P
MATE! Whats your problem!!!....do you have a problem...me think's so.......I had a simple request your simple mind could not decipher! :(
I don't use PC(because I hate Microsoft OS's)....therefore I cannot use FAST.
And no I don't no my VIN# off the top of my head.....maybe I should....hey look if it really makes you happy I'll get it tattooed onto my arm.
:rofl:
P.S. sorry....i'll stop the highjack now!
Edited by Jetwreck
Cheers
Andy
Not really optioned. Axis and ARX panels are interchangeable in models up 2001-2004 (the flares match up). So all the previous owner would have to have done was buy an Axis front bar and get it and the flares pained the same colour as the body :(
Also, I believe that if you wanted Autech bits, you had to buy the Axis... Nismo can option up most models from the Nissan dealership (seems they didn't like touching the ARX though :( ), but Autech only did the complete car from what I can gather.
I don't think they wanted to mess with perfection of the ARX
well mine has nismo floor mats - i know they would probably be able to be bought at every corner shop in japan. and nismo suspension. it looks as old as the car so id suggest very early fittment or factory fitted.
here are some pics.
Andy tried but his is F$#king useless :)
dude, i have the service manual!
come over and ill copy the pages you need
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
