i have an emanage ultimate with direct plug and play loom (n4)
these looms are few and far between... no splicing and sus ecu wiring needed
timing control, fuel and air map control... boost is possable with the addition of a boost sensor ($120 or so)
SENT AUS WIDE $750
Msg me 0400099986 or PM thanx
https://www.sau.com.au/forums/topic/311906-greddy-emanage-ultimate-cheap-cheap/
hey mate, any chance of a pic on here???
if not can you send one to [email protected] please, also do you have wiring diagram for this item as i will be puting it in my vl with the rb25det conversion.
thanks
thanks
here ya go mate... its just a matter of getting the 2 big rectangle plugs... one goes to your ecu, the other goes to the plug currently pluged into yout ecu... the wiring diagram is on the greddy website and here... ill get onto it now for you tho...
what state you in??
Just doing some research on these units, to runtjis unit in a gtr you need to change 2 wires around and ground one. I've got the diagram
Hey mate, what exactly needs to be done to fit this to a GTR?
I thought the N4 loom fits GTR?
Cheers
  • 2 months later...
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
