Start reading through the sticky at the top of the forced induction section. Its a road travelled by most of us here so there is plenty of information. Set yourself a goal and a budget and stick to it.
Also i think you mean 3.5" catback.
Edited by PM-R33
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5132842
Depends what you want. If power is all you are after than start with modifications that will help you now, but will also not need to be replaced down the track
ECU upgrade, fuel pump upgrade, intercooler upgrade, boost upgrade etc.
The first goal people usually do is try and max out the stock turbo. Good gains can be had with it, once you get over it (which you will fairly quickly) it's turbo upgrade time. With this comes a whole new can of worms and cash.
You'll find most people try and achieve a power goal or a role for the car (street car, drag car, circuit car or a mixture of these). Honestly just start reading through that sticky and get your knowledge up so you know the weaknesses of the car, what max's out at what power levels and how much things cost.
Very easy to spend $10,000-$20,000 on these cars without even doing half the things that you want, especially when starting with a standard car.
Edited by PM-R33
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5132902
http://www.skylinesaustralia.com/forums/Ni...Mo-t282082.html
That is my favourite guide. I am up to the end of stage 1 plus a Trust Intercooler. Mine makes 190rwkw. I am preparing for a 250rwkw hi flow setup.
My advice would be:
1. dump pipe and front pipe.
2. $28 turbotech boost tee
2. tune with nistune
That should get you 180-190rwkw. Then you decide how far you want to go. The only thing I have on top of that is a Trust return flow intercooler. But thats more because I will need it for my next mods.
Edited by Harey
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5133277
not so keen to sell it, to be honest it's quick enough for the moment. 6 months ago i was driving a 2.2L 1994 camry, so anything would have seemed hugely fast.
I'm not one for much but have been pretty even (up to 100km speed limit) with v8 utes even though the tc tries to kill the fun (lol), the only car to stay ahead was an xr6turbo
a mate of mine has put extensive work on clean air in is NA supra which is now pulling 160rwkw which is a little concerning haha
Yeah, thinking of keeping most of it stock and improving airflow, drone etc...
300rwkw ~= 400kw at the fly ~= 530hp at the fly > ferrari 430 (in max hp anyways) (>2 x stock!!!)
holycrap lol
now you know the cost, would you guys do it again?
have you had much trouble with mr plod??
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5133852
While your getting used to the stock power save some money for some of the common faults with the GTT.
Depending if it was done before have a look at the tie rod ends and castor bushes. Depending on the Kms you may need to change the coilpacks most seem to start to die at about 60,000kms to 100,000 kms and make sure you get a good workshop to look over everything. No point throwing $$ at a car that won't handle it.
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5133994
hi my first step was to boost it to 10psi but as you know from my other thread i have the same issue as you and its already boosting to 11psi , so my next step (when the wife lets me) it to insall this post-70954-1268634668_thumb.jpg
and then a high flow cat . after that i might consider getting rid of my series 2 bumper and get one that i can fit a front mount intercooler in , then then then ........ i sapose the wheels will fall off before i get to do what i want to it i wish i had deep pockets , i want a power fc (ecu) but no way will the missus let me spend $1700 lol
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134143
very good. I'm in the middle of a cash flow erm, discrepancy? atm so simply happy with what i've got (tho trying to figure out what "that" is) and making plans for the next few steps later this year (it is nice to dream).
definitely looking at front and dump pipes (their stock) and maybe a better catback and tip, as well as cat, and pod filter etc.. just aiming for smooth flow.
will be good to finally determine whether or not its running stock boost, though i'm sure you feel the same
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134186
go a nistune, as good if not better technically to a power fc, much cheaper ($300 for the parts installed into your stock ecu + $500 for a full tune)
Plus the cops cant say anything because you are using the factory computer!
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134225
lol what that is is your front pipe and dump pipe all in one
it goes from your turbo all the way to your cat. it splits the gasses from your waste gate and exhaust (because the standart one trys to push the two down the same pipe causeing turblence (less flow))
so it splits the gasses and re joins them just before the cat so the high flow from your exhaust is flowing and drags the wastegate gasess through with less drag, they are garenteed to give you more horse power expercialy since its 3" straight out of your turbo.
better than the short split pipe they sell on ebay for $98 , they are not garenteed to give you more power (as fare as i know).
get that and a high flow 3" cat from ebay $170 and your exhaust is done !!!!
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134287
look id love to , i got the same sort of qote from a guy in dandy but my wifes pregnant so i have to wait till after babys born to do anything , sucks so bad .
iv been looking for the sister board its a type 4 yeah ?. but cant find one . i was going to install one my self and then get a full tune (i have seen them in the past for $220 self install but didnt have the car yet at that stage)
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134299
That's pretty much what i thought when i saw that: front + dump + separate wastegate all in one, i didn't know they existed. Its def the type of thing im keen on, its on the list!!
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134336
Hahaha I didnt mean go out and buy it this second, just saying if you are going to buy an ecu that is what I have and would recommend.
Yup type 4. Dr Drift charged me $800 for type 4 board fitted with full tune. So somewhere around 300 for the board installed.
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134378
yeah sounds good its also on the list for me , i guess its just save save save .
https://www.sau.com.au/forums/topic/311916-blank-canvas/#findComment-5134391
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
