Not many workshops know how to do them in a fashion that doesnt crease the lining. There's a trick to do them neatly.
Yeah, mine were not done neatly either, seems there are huge washers used and the lining is bulging in sections :(
It's no biggie but it's not good workmanship :(
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5133151
I have seen some work shops actually drill right through the roof of the car and bolt them in the valley above the tailgate.....Not pretty and leaves a huge risk of rust and water leaking into your car. On top of that they made three large holes in the plastic cover in the roof at the tailgate and when they mounted the anchors the plastic cracked........
thank god mine were done well. Thanks Ben.
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5133158
Ouch, I hope that is not how mine has been done. I havn't taken it off to have a look but now I'm afraid to do so.
I do have a small water leak on the right hand side of the vehicle right at the back, however I'm hoping this leak is coming from the small crack in my rear sunroof rubber. I do have a new rubber but Hornsby Nissan were unable to fit it due to needing specialist equipment. I'm hoping someone like Windscreens Obrien or someone who specializes in servicing automotive sunroofs can fit the new rubber.
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5133162
Crease the plastic, leak water past the rear door rubber, look bloody stupid, the retard that installed mine should be shot. Wanker. Surely there are simple instructions to follow for installing such an important safety item, the government wouldnt let people just guess how to do these things would they?
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5133170
Apparently they would.......
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5133230
Yeah it wouldn't surprise me to be honest.
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5133252
+1 from me as well... :(
Properly fitted with no roof lining creases by Northshore...
On my old R33 4dr, this has also been done properly, and my car was one of the few where they were not installed through the rear speakers... Could not belive that SEVS workshops were just drilling through the speakers to make their job easier..
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5133255
Mine are badly done. Straight through the metal behind the boot seal.
They leaked in the rain until I sealed them up.
I actually need to take it all apart and check for rust.
The interior trim is wrecked as well.
I honestly don't understand the kind of mind that is happy to do such a shitty job.
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5137459
sounds like the same place complied your car as my mates.......... :banana:
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5137614
Actually I'm going to make a confession. Before I realised the child restraint anchors were on the roof, I used the latches on the boot floor thinking they were the right ones to use..
Using your method, you can fit several car seats :D
The anchor points are good though, I've used them with cargo straps... nice and strong :banana:
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5137821
  • 4 weeks later...
Hi, Anybody from NZ here that has had the babyseat anchors added to their M35 Stagea? I'm located in Hamilton.
Cheers,
Tom
I would have "assumed" that your compliancing rules would have been the same as ours, and it would have been done before being registered.
Anyway, if you need them done you may be best off talking to a compliancing workshop, don't know if there is one in hamilton but it could be worth a shot.
https://www.sau.com.au/forums/topic/311917-nissan-stagea/#findComment-5177079
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
