Any symptoms? Splutter? Missing?
Had anything in or out?
Tried to clean anything when all of this happened?
Why was it running even at 0.5bar when it should have been 0.8 on a squirt?
changed the oil not long before it happened and the car has always been runnig on 0.5 since i got the car last year.
other than that the car is running good.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5134107
If you are going off the stock MFD, can you tell what it reads as idle?
Have a listen at idle in the engine bay for hissing too. Theres a thin vacuum hose that goes from the rear of the engine to the sensor pickup near the driver side strut tower. Have a feel for leaks.
Mine split ever so slightly near the join. Symptom was almost no vacuum on the boost gauge and had the same issue when giving a slight boot. You would also occassionally see a bit more fuel in your exhaust.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5138199
hey mate you were right .the pipe going from the rear of the engine to the boost sensor split right behind the engine.thanks a lot for your help.
it is boosting upto 1bar now.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5142223
One thing that can do it is a collapsed cat. It happened on my last car.
hi mate i checked the cat today and found the exhaust was leaking from both sides, but the cat it self was ok. i changed the gaskets but it ends up it wasent the problem. i found the pipe that goes to the boost sensor was broken from behind the engine. but thanks for all your help.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5142227
sounds like you got it sorted, but for workshops i would highly recommend Status Tuning (soon to be Chequered Tuning) and also of course Race Pace Motorsports if you need the car checked.
Any mods yet? Trent (Status Tuning) can work some real magic if you need something tuned :)
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5146776
Any mods yet? Trent (Status Tuning) can work some real magic if you need something tuned :cool:
no i havent done anything to the car yet, i whant to pay it of first. wher are those work shops based do you now?
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5146944
south dandenong and bayswater, off the top of my head - Status is deadset easy to get to, very close to EastLink. Don't know about RacePace.
doesn't really matter anyway. If it takes a while to get to a good tuner, it takes a while to get to a good tuner. It is EASILY worth the time/effort to take your car to a place that knows what they're doing.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5147103
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
