Any symptoms? Splutter? Missing?
Had anything in or out?
Tried to clean anything when all of this happened?
Why was it running even at 0.5bar when it should have been 0.8 on a squirt?
changed the oil not long before it happened and the car has always been runnig on 0.5 since i got the car last year.
other than that the car is running good.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5134107
If you are going off the stock MFD, can you tell what it reads as idle?
Have a listen at idle in the engine bay for hissing too. Theres a thin vacuum hose that goes from the rear of the engine to the sensor pickup near the driver side strut tower. Have a feel for leaks.
Mine split ever so slightly near the join. Symptom was almost no vacuum on the boost gauge and had the same issue when giving a slight boot. You would also occassionally see a bit more fuel in your exhaust.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5138199
hey mate you were right .the pipe going from the rear of the engine to the boost sensor split right behind the engine.thanks a lot for your help.
it is boosting upto 1bar now.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5142223
One thing that can do it is a collapsed cat. It happened on my last car.
hi mate i checked the cat today and found the exhaust was leaking from both sides, but the cat it self was ok. i changed the gaskets but it ends up it wasent the problem. i found the pipe that goes to the boost sensor was broken from behind the engine. but thanks for all your help.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5142227
sounds like you got it sorted, but for workshops i would highly recommend Status Tuning (soon to be Chequered Tuning) and also of course Race Pace Motorsports if you need the car checked.
Any mods yet? Trent (Status Tuning) can work some real magic if you need something tuned :)
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5146776
Any mods yet? Trent (Status Tuning) can work some real magic if you need something tuned :cool:
no i havent done anything to the car yet, i whant to pay it of first. wher are those work shops based do you now?
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5146944
south dandenong and bayswater, off the top of my head - Status is deadset easy to get to, very close to EastLink. Don't know about RacePace.
doesn't really matter anyway. If it takes a while to get to a good tuner, it takes a while to get to a good tuner. It is EASILY worth the time/effort to take your car to a place that knows what they're doing.
https://www.sau.com.au/forums/topic/311923-r34-gtr/#findComment-5147103
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
