boostmeister got me back in the mood for photoshoping... noones posted anything for ages :mad:
I didn't do much to it... i just wanted to have a go at deep dishing the rear wheel(s).
I started it an hour and a bit ago :mad:... can anyone pick the defect? think r32 and you'll get it :ghost:
:D
orig:
hmmmmm
https://www.sau.com.au/forums/topic/31195-corvette-c6/
