Set of Rays Nismo LMGT2 wheels. Front 17 x 8" +35, rear 17 x 9" +38.
A bargain at $700 including tyres !
Some gutter rash on each rim. One front rim has a dent in the outer lip from hitting a stupid jutting out curb (also damaged tyre wall - see pic). This wheel is NOT buckled and is perfectly drivable - it is only the outer lip that is dented. It can be repaired - but the whole set is perfectly drivable as is. I was driving on these for a few months after this dint and there was no wobble or alignment issues. You could have the whole set refurbished and they would still be cheap.
Hell it's not a bad price even for the rear pair with tyres.
One centre cap is also missing.
I want to get rid of these rims as I am moving to Sydney and these will just collect dust in storage at a friends if they are not sold.
Perfect as track or street rims for R32, R33, S13, S14 or S15 (also good fit for RX7 S4 & 5).
Rear tyres are almost new 255/40 Falken 595-SS, front tyres are mismatched due to puncture 2 years ago.
Rear tyres are 90% - 255/40/17 Falken 595-SS
Front tyres ~40% - mismatched.
All 4 wheels
Rear #1
Rear #2
Front dented
Close-up of dent
Front #2
Wheels are located in Brisbane - pick-up is MUCH prefered.
Can deliver to Sydney at beginning of April.
Edited by simpletool
https://www.sau.com.au/forums/topic/311967-rays-nismo-lmgt2-17-wheels-cheap/
Reduced to $600 !
Need these gone by Saturday (2 days time) - or into storage they go.
If you are in Sydney I can have them sent to my new address and you can pick-up (Waterloo). You'll have to let me know within 2 days though or they will stay in QLD.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
