Cnc ,fabrication,roll Cages Almost Anything Can Be Made
hi all i,ve just started my owen performance fab and machine shop
we can make almost anything u may need for a skyline and most nissans
also do cnc programing , tig ally and s/s
crmo andra spec roll cages , brake upgrades ie custom brake engraving
can organize dyno tuning
call brendon on 0437799696 or pm thru here
Edited by NIZ-26T
  • 1 month later...
hay buddy
can u make custom coilpack covers/ valley covers for an rb25det neo in alloy or steel (whatever really)
also
an oil catch can and water washer bottle in 1 in alloy (or steel)
let me know and ill send u my design
cheers
julz
Edited by GUN_METAL_GTR32
  • 3 weeks later...
yes im sure many people are busy like you but if you want to post a thread in here selling fabrication services then you should be willing to check it and respond - dont forget that you can setup email notifications so you dont have to sit here waiting for replies.
Dont ruin this area by not supporting your fellow forum members, or i will simply remove the thread as it isnt any benefit to SAU's members.
  • 6 months later...
  • 1 month later...
Also how much for a 4 point cage to suit ke20 with removable intrusion bars?
cheers
sorry mate closed over xmas. total for cage and tunnel $1400 inc GST
also what type of racing are you doing CAMS or ANDRA
    • If a magnet doesn’t stick to anything except another magnet then it’s not a very good magnet and is probably just a piece of steel
    • Magnetic drain plugs are fine. Just don't buy cheap shit ones. They're actually better than letting magnetic shit float around in your oil. The magnet also didn't just "fall out". OP was drilling the plug out which allowed it to come out. Even some OEM plugs are magnetic.
    • I have to say, I was briefly considering getting a magnetic drain plug but never could be bothered out of laziness/cheapness and now I'm very glad I didn't.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
