New Standing Mile Speed Record... Ford Gt40
Hey sports fans,
I had an intersting day in Miami (well west of Miami) at the Top Gun Run- Miami Mile.
www.topgunrun.com
The event was held at a private airport... it was very fast and the furious "race warz"!!! ha ha ha...
lots of top end cars, with some serious modifications!!! No less than a dozen vipers (8 were forced induction), 6 forced induction Lambo's, 5 brand new GTR's, 4 GT40's and a bunch of other exotics...
I was invited by Trevor from wizard of nos http://www.noswizard.com/ ... who buy the way set up the world class, record setting nitrous kit in 12minutes. Trevor was there to run some new equipment on Performance Power's 1400hp twin turbo GT40. Insane!!
The car runs around 10.5:1CR, boost spikes to around 37psi, twin precision turbo 75mm turbo's AND 100hp jetted shot of gass... Nut's just nuts. The car struggles for traction at 200mph in 6th gear!
The first clean pass for the day resulted in 232mph.
Then an hour later, with no set up changes other than activating the nitrous the car ran 252mph- with a missed 4th gear and average launch!!!
I belive 252mph is the standing mile record for USA and I'm fairly shure the rest of the world...
Here's a few pictures:
Edited by XRATED
Yeah it was absolutly mental!!! It actually makes you sad to see that only 200 or 300 people spectators turned up to watch. But there was 80 odd entrants for the event...
These yanks throw some serious cash at top end cars!
Also, the only skyline GTR at the event ended up with a hole in the block as big as your fist!!! But his first run was 192mph..!
Cheers
J.
PS Off to moroso next month.
Wow they throw some serious coin at those cars. Must of sounded amazing out there.
Yeah... Insane amounts of money. Alot of wealthy people with really cool toys!!! Actually the guy that won last year was really pissy that hiss heffernan twin turbo'd 08 Lambo got beaten. It had veeeery big turbo's on it too... from a rolling start, it took 60 or 80 feet just to come onto boost! He's now looing at a full wizard of nos nitrous set up.
It blows me away the kind of money people are throwing at these things.... And I work on SUPERYACHTS!!! ha ha ha the biggest rich boy toys of all.
There is somthing like 700k in the development of the GT40.
goes ok. i can understand why he missed a gear, imagin the nerves
Naa Johnny was overly exited more than nervous.
  • 1 month later...
We're going back out to hopefully take the record to 270 on sunday.
This time I will be there to make sure that they don't negate my "boost by gear" system by running too much boost in the lower gears.
That's my sleeper Infiniti M30 (leopard) with L28et in the background.
Well sports fans, the record was re-set at 266mph by the Hoffman GT40 last week... Unfortunatly I didn't attend (work... blahh).
I'm shure Performance power/ Johnny are keen to get it back.
Exiting times for standing mile!!!
Cheers
Justin
Well sports fans... there are no more high speed runs untill Feb next year. The weather is too hot and it WILL rain twice a day every day!
It's very cool in south florida... I one friday-Sunday I:
Went to ultra fest (dance music consert- 75000 people a day)
Had a ride in a fan boat through the everglades
Chewed through 120 rounds through a glock 17 .45 at a local indoor range
Gambled at a genuine American Indian Casino
Went to a car show
Went to a Top Speed Run (as above)
Then went to southbeach Miami for a drink
Ha ha ha...
And all I want to do is to go home and work on my GTR... :-(
  • 5 months later...
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
