Hi guys and girls
I'm flying up to Brisbane on Wed and staying for a few days in an apartment near the city (Melbourne st -westend I think) and thought it would be a chance to put faces to some of the names I regularly see here on the forums.
Looks like there is no organised cruise this weekend but I was wondering if you (or other imports) meet informally at any local spots (that are easy for rubber necked visitors to find)
I don’t know if I will have Internet access at the apartments, (so it may not be worth replying later in the week - I'll logon if I can though), but I just thought it would be good to see what goes on in the land of the banana benders.
https://www.sau.com.au/forums/topic/31199-brisbane-visit/
Harry's Diner (northside) is supposed to be very good, not exactly sure which nights.
Macca's carpark Milton is good Friday nights.
Broadwater carpark (gold coast) on Saturday nights - after 10pm :D
https://www.sau.com.au/forums/topic/31199-brisbane-visit/#findComment-630055
Or alternatively, go to Roma Street on a Thursday night and sit there and wait for the many cars/groups to come in and leave. I personally won't be out on thursday night and probably not till late on saturday night (family engagements) if at all. Otherwise I would have tried to organise a cruise :|
https://www.sau.com.au/forums/topic/31199-brisbane-visit/#findComment-630582
Thanks for the quick responces.
Looks like i'll have to visit milton maccs on Thursday night.
What time do things kick off? no use getting there 2 early coz I'll only end up eating too much (can a stomach be considered excess luggage when flying?) I'd rather go home with a few new bits for the car.
https://www.sau.com.au/forums/topic/31199-brisbane-visit/#findComment-630604
predator you have no excuse, i was late for a cruise once i put my dash back in in a bp carpark while i was waitin for people to show up.
well... it might take slightly more time to get this back together :P
but its still driveable - i just have to whack that support bar back in. Speedo, etc is gonna have to sit there resting behind the steering wheel. Ghetto mods at its best.. hehe
https://www.sau.com.au/forums/topic/31199-brisbane-visit/#findComment-633424
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
