heres a pic of a back to back comparison stock vs HKS 260 9.0 cams
motor is stock standerd with a GT30R .63, xs power high mount manifold, EMS stinger ecu and gtr injectors.
cams DO HELP dont listen to those that say they are a waste on the rb20's
^ umm would that not depend on who's dialling in the factory cams?
Some people don't even try any adjustments.
But you cant discount Roy's very own testing just because yours is different.
thats the 2nd motor ive seen these cams in that have made a difference.
It could be possible Roys might have been installed with the wrong dial in or a tooth out on a gear.
I didn't say factory cams cant be improved with adjustments. but aftermarket cam's WILL result in greater gains.
the above dyno sheet doesn't show the torque curve, that was the most impressive part with the curve staying alot more broad across the rev's
Could have been your tuner didn't even properly attempt to play with the factory cams...
See where this is going?
We can play he said/she said all night if we want. For you to say "dont listen to those that say they are a waste" is wrong.
Thats why i am going back to the 10cm housing, Plazmaman plenum...will see if cams work for it then. Need to beat that R31 fella making more power then me :D
Come on Trent, give me the specs of something you have seen work. :) I am torn between installing my solid lifters with some 260/10.25mm cams to go with the 10cm housing and 2.4L bottom end or just keep my money in my pocket and keep reving the crap out of the lil std motor and see how it goes. I am so hot and cold about all this :( Its safer to go with a known RB26 or RB30 setup, but.... :)
QFT......queue natalie imbruglia :)
The HKS cams may work better then the Apexi cams i had. But that is the catch, if the tuner has spent time on the dyno tuning the engine with std cams and cam gear settings. Then install the cams and go through all the same rigmorol trying to get them dialle din and working. In my case the car went backwards with very similar spec cams as to the HKS.
I dont think there is any chance that the tuner isntalled the cams a tooth out etc etc. Whislt anything is possible, a lot of time was spent trying to get the power and response back and he is the builder / tuner of some of the quickest Skylines in the country (Racepace), so would be shocked if that was my problem.
But, not to say the HKS cams are not a little piece of majoc...lol, i sold my HKS cams, maybe i shoudl see if they guy still has them :P
I can tell straight up from that graph that the dyno operator has changed ramp rates to manipulate the curve... plain as day.
Come on Trent, give me the specs of something you have seen work. :D I am torn between installing my solid lifters with some 260/10.25mm cams to go with the 10cm housing and 2.4L bottom end or just keep my money in my pocket and keep reving the crap out of the lil std motor and see how it goes. I am so hot and cold about all this :( Its safer to go with a known RB26 or RB30 setup, but.... :(
That i'd like to see, the extra 0.4 and the lift should work well with the 10cm.
  • 3 months later...
Considering getting the 256 deg poncams for the rb20 as well but I am using a HKS GT-RS turbo which is a little bigger than the 2530.
Surely the larger turbo would be better suited to the aftermarket cams?
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
