Hey guys,
I did a quick search but couldnt realy find an answer.
My Question is , How strict are the pits/ cops on the wide body FRP front guards?. Do I actaully have a chance of getting my car registered with FRP front fenders. (I also have a frp bonnet but im going to bond the metal support from a stock on to it).
My mate kindly informed me that because im removing a crumple zone item (metal guards) and replacing with Fiberglass ones, this is defect worthy =(. But apparently the rear wide fenders are ok, if they are bonded over stock items.
Any info / suggestions / help would be great guys
https://www.sau.com.au/forums/topic/312008-frp-guards/
quick answer - very
long answer - if the guards in question have been manufactured by someone who has already had them proved to conform to ADR 69, 72 and 73, and provide documentation as such, the only thing you will need to worry about at the pits is wether they have been mounted correctly. If the guards cannot be certified then IMO dont even bother. The structural and hardness testing to prove they will conform will destroy at least one set of guards, and set you back a few grand to get done anyway. I dont have a copy of the vehicle modification guidlines with me atm, but if you have a look on the dop website, check out the modification guide for street rods, as it covers all the requirements for FRP for both full body and bolt on guards
*rummage*
http://www.transport.wa.gov.au/mediaFiles/lic_cp-105b.pdf
section 5
*edit - Bard, its got nothing to do with being structural, its all about frontal impact protection for ocupants and pedestrians
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134243
You sound like you know what your talking about.....otherwise thats some awesome bullshit you just spun lol
But seriously, that sounds very true and i do not doubt you for 1 minute.
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134279
Thanks for the link guys
The way Im reading it, its differentiating between non intrusion and structural.
The testing appears to be limited to structural items, from the way im reading it.
So going from that , the only stipulation for bonnets is that they are 3.5mm thick and use stock mounting… ?
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134302
The way I read that is: guards and bonnets are not required to be tested/certified, they must be at least 3.5mm thick (without gelcoat) and utilise stock mounting locations with a neoprene, then steel washer at least 20mm in diameter.
https://www.sau.com.au/forums/topic/312008-frp-guards/#findComment-5134569
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
