if you are attemptingto install a sunroof at home.. you are really asking for trouble.. is it worth the cost of a f**k up if you get it wrong?
Nahh mate want to get sunroof mob to fit it just after some info if there is difference between series1 and series 2 sunroof
Non sunroof models do have the mounting points to bolt the roof up, there are also trace lines to cut the opening...the hardest part is sealing the two sheets of metal.
You need to install the drain pipes into all 4 Pillars (As and Cs), and wire up the electronics.
The roof trim is different, likewise the map lights are different above the driver/passenger.
Is alot easier to get a business to do it - if they f**k up, they pay for it.
In all honesty, buy an aftermarket sunroof though...you won't regret it.
The factory one has the option of tilt up, or sliding back inside the roof. Aftermarket sunroofs have alot of options.
Dunno where you're based, but check out this site:
http://www.prestigesunroofswa.com.au/
