For Sale: Control units to automatically extend/retract your wing mirrors after you leave your car
PRICE: $49ea
Postage: $10
QTY: 10+
FULL DESCRIPTION:
  • Designed, constructed and tested in Australia!
  • Specifically tailored for Nissan Skyline with Electric Folding Mirrors
FEATURES:
  • Folds side mirrors in automatically approx. 15 seconds after vehicle has been turned off
  • Uses ACC/IGN +12V as activation trigger
  • Uses direct 12V battery power source (IE can operate while car turned off)
  • Low standby power consumption
  • Short duration relay switching for extended relay life
  • 2A maximum current (relays)
  • Overrides existing switch assembly whilst automatically folding mirrors in/out, then reverts back to the original Nissan fold in/out feature whilst at idle or disconnected (R33 model only)
  • 5A fuse protection
  • Reverse polarity protection (+12V & Ground wires)
  • All relays and control circuitry contained in a compact, lightweight plastic enclosure (Length 3in x Width 2in x Height 1in Approx)
  • Integrates into existing wiring loom. Only minor modifications necessary. (A few cut wires and some soldering)
  • Concise installation instructions (tested on R33 Skyline models) WITH images and diagrams.
CAR REQUIREMENTS:
  • Designed for Nissan Skylines with electric folding mirrors
  • Both side mirrors are in good working order
  • Maximum folding time is 4 seconds per mirror
INSTALLATION REQUIREMENTS & TOOLS:
  • Basic knowledge and understanding of car wiring (anyone who has installed a car CD player should have no problems)
  • Soldering Iron
  • Solder
  • Wire cutters
  • Stanley knife
  • Electrical tape
NOTE: Auto-folding side mirror unit has been tested and installed on R33 model Skyline. For R32 and R34 skylines, the installer will need to identify relavent loom wires with the help of installation instructions supplied. It may also be possible for other Nissan models to use this unit, however compatibility cannot be verified by the manufacturer.
ITEM is located in SANDRINGHAM, MELBOURNE.
Built these a while ago (see following link for more details):
http://www.skylinesaustralia.com/forums/Auto-wing-Mirror-Retract-t295040.html
Can also arrange installation at additional cost (if needed). PM if you're interested!
  • 3 months later...
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
