Hi,
Has anyone had a play with an iPhone and an external GPS unit ?
There is an App out called RoqyGPS that allows you to use an External GPS unit via bluetooth for all the navigation apps that iPhone currently have like Tom Tom and Navigon.
An external GPS which you can pickup for around $50 on ebay is alot better than the current GPS unit/chip inside the iPhone, reviews state there is no lag and one user even compared it to there stand alone Tom Tom GPS unit and said they worked identically, Also you can use these on older 2G iPhone that do not come with GPS.
Ideally I would love to run the iPhone through to the OEM screen through the leads C Rogers can supply plus another App that is out (Screen Splitr) but the problem I am running into is how to answer calls while the iPhone is sending AV output through to the OEM screen :)
I cannot use a portable bluetooth handsfree kit as the iPhones bluetooth is being used for External Bluetooth GPS.
There is a Non-Bluetooth GPS Receiver for the iPhone that I have seen called the GPS360 that plugs into the dock/bottom of the iPhone but this would not allow the plug for the AV output to be plugged into the iPhone. :D
I am not worried about touching the iPhone to answer calls or enter addresses and am waiting for a reply from Chris to see if when you answer the iPhone while AV is being outputted will you hear the call through the Cars Speakers... So I have also looked into an external mic for the iPhone which will work in this case but the problem here is all the info I read about external mics is that audio is transmitted to the headphone jack as the iPhone thinks headphones are plugged in.
If anyone has overcome this problem (not with a complete standalone GPS unit, I want to use the OEM Screen ) , Or has any other ideas. Please post I am pretty much googled. :thumbsup:
Edited by Cruzen
  Cruzen said:
Hi,
Ideally I would love to run the iPhone through to the OEM screen through the leads C Rogers can supply plus another App that is out (Screen Splitr) but the problem I am running into is how to answer calls while the iPhone is sending AV output through to the OEM screen :O
There is a Non-Bluetooth GPS Receiver for the iPhone that I have seen called the GPS360 that plugs into the dock/bottom of the iPhone but this would not allow the plug for the AV output to be plugged into the iPhone. :O
If anyone has overcome this problem (not with a complete standalone GPS unit, I want to use the OEM Screen ) , Or has any other ideas. Please post I am pretty much googled. :(
I guess, the easies answer will be: Set you IP to auto anwer income call model, connect the mic to dock.
Buy the TomTom car kit for iPhone. I have it and it's excellent, I use TomTom navigation with it and it is as good as a stand alone unit as it has a GPS enhancer chip. Also gives you hands free through Bluetooth for calls. A little pricy at $160 but I think worth it. I wouldn't bother with the oem screen in the v35 personally, it's a novelty.
Edited by Easy Tiger
Good idea , didn't think about 'Auto Answer' but regarding the mic connected to a dock would this work while still outputting AV ?
