Im curious if anyone has done this when using their std oil pump and if so, do you know roughly what thickness shim will net what oil pressure increase?
Cheers.
I normally use a M6 spring washer that I straighten. I think they are about 2mm thick and it get's you roughly 10-15psi on cold start and in the top end when hot but doesn't seem to make much of a difference at idle when hot though. If anything it might be 2-5psi idle/hot
this the done thing? any probs wth doing it?
just didnt know if it was a done thing for all the pumps, i have a 26 pump on my 20, would it still be any better with more
pressure on the valve?
Unless your motor is out of the car, there would be no point doing all that work for such a little gain. I only do it as a small aid due to the fact the 20 year old pump can do with a bit more oomph. The oil pressure increase is not really going to do too much for you.
Also, there is no difference between a 26 pump and a 20 pump unless it's an N1.
they do this to rb30 oil pumps. its a common "fix" for the lower oil pressures the RB30E pumps produce at higher RPM when putting a DOHC head on an rb30 compared to DET pumps (for getting away with using a RB30E pump rather than buying a DET pump)
Edited by SECURITY
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
