Item Summary: advan tri spoke 18x 9.5 all round
Condition: Used
Reason for Selling: not needed
Asking Price: 800
Delivery Methods: PickUp
Contact Info: pm me
Extra Information:
hey guys got some advan tri spoke rims here the got a bit of rash nothing real bad there 18x9.5 all round 5stud fronts are +38 offset rears are +22 800 or offers
so pm me
thanks
https://www.sau.com.au/forums/topic/312075-advan-tri-spoke-18x-95-all-round/
tyres on them are prob only good for skiding also have a pile of skid tyres to go with them..
need gone this weekend open to offers 0420737330 txt as i work and wont pick up
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
