Hi guys. Been scanning through old posts but cant seem to find the questions im after.
Im trying to choose between an r32 gtst and an r32 gts4. Obviously the 4wd of the gts4 will be an advantage on the strip etc but does the extra weight make a big difference?
Can anyone tell me the stock 0-100 times of these 2 cars?
Is it possible to get the gts4 into a WRX beater pretty easily? Id be after a 0-100 time of around 5 seconds and 1/4 time of 13s. How hard is this to get?
Are the gearboxs on the 4s the same as the gtrs and if not how strong are they?
Any answers appreciated.
Tom
https://www.sau.com.au/forums/topic/31209-quick-newbie-question/
Anyone?
both cars in stock form - the gtst is faster as it is i think 100kg lighter.
BUT that is if they are both stock.
I can keep up with a 12sec rex up to about 85kmph, after that its gone tho.
im preety sure the gtr box is a bit stronger???
but the gts4 box is still a strong one.
gts4 is quite amazing from the lights.. i usually take off at 6500rpm and ride the clutch a little... it chirps a bit but that is all.
The GTS-4 has the same box as a GTR. A popular mod is to do an RB26DETT conversion, with which you will end up with pretty much a GTR but with skinny guards (think sleeper). It's pretty costly though, so if money is a concern an RB25DET conversion might be better.
The GTST or GTS-4 is obviously heavier, but the drive-line is extremely strong. Buy a Rex and you will destroy clutches and gearboxes faster than you would ever believe possible, if you drive it hard. The Skylines are indestructible, and take some serious mods without becoming unreliable.
The GTS-4 gearbox used with the RB20 has different ratios, but is otherwise identical to a GTR box, and is just as strong. Same with the diffs.
i had a rolling start drag with a new STI the other day in my R33 and i was pulling away from it, WRX's arnt that quick after they launch imho
Depends what's been done to them (like any car i guess)
But it is my 2nd fav car to chop, after the commonwhore that is of course :headshot:
sorry to hi-jack the thread a little, but i'm in the process of bringing an R32 GTS4 over from japan (read getting the money together :Oops: )
but will be performing the RB25DET swap over on it (along with a decent level of modifications), anyway, my question is will the RB20DET g'box bolt up to the RB25DET block easily or is there some work that needs to be done?
thanks
Shane
Hi Shane, the issue here is the 4wd sump is different (wider) to carry the front diff and drive shafts. The 4wd block is therefore a different casting to allow the sump to bolt up. Basically you can't use a 2wd block and expect the 4wd sump to bolts up. There are 4wd blocks in RB20, RB25 and RB26 and 2wd blocks in RB20, RB25 and RB30.
So if you want to put an RB25 into a GTS4 then you have to use a 4wd RB25DET out of a Stagea. Not that common. Or get an RB25DE (non turbo) 4wd block out of a R33 GTS4 and swap the internals from a 2wd RB25DET.
That's why the common upgrade for a GTS4 is an RB26DETT, it's more expensive but much simpler.
Hope that helps
Sydneykid, thanks for that info, damn i always thought the R33 GTS4 was turbo'd, oh well.
i was going to get the internals re-build anyway so the 33 block may be the way to go (balanced/shot peened crank and rods, forged pistons etc etc)
the only other option i can see is to have a custom sump made up but have it modeled off the original 4WD RB20 one. that way a few baffles could be put in, stop the oil surging at the track :(
Shane
Yeah, i read somewhere ( probably a thread here :( ) that Nissan didn't make a turbo'd R33 GTS4 because they thought people might buy it instead of a GTR and they did want the cars to be that similar?
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
