BRAND NEW 19" Work Meister S1
Specs:
19x9 +35 REAR
19x8 +32 FRONT
Staggered fitment and Aggresive offset. fits many nissan like s15 and skyline. also suits others such as accord, euro, civic, IS250.
Price: $3700
Contact by PM or SMS at 0414 990 603 (Denny)
Pictures:
IMG00277-20100309-2326.jpgmanmanjdnfvdj
Edited by jaydm
https://www.sau.com.au/forums/topic/312120-new-19-work-meister-f-19x8-r-19x9/
