It has more than mine does, you get a wheel brace at least, mine just has the tow ring. There is no spare, no goop, no jack, nothing in these, they come with runflat tyres from the factory. I bought a 370Z donut (which clears the akebonos), a jack and wheel brace for mine as I had normal tyres fitted last time. I just throw them in the boot if I am going out of town.
looks like it has no spare so im guessing there should be goop and a jack and handle. Anything else? im going to try and order all the stuff from Nissan if i can or get some sort of aftermarket kit.
Well this is depressing When the terminal failed, what did it look like/what happened? I didn't even realise I had melted the factory connector until I tried to remove it and couldn't. Then looking at it from the inside of the fuel hat, I could see that the internals of the connector had melted. It would be good to get a heads up what to keep an eye out for with the Taarks terminal. I would love to eventually run something like the FPG setup, but I cant see me installing it with the tank in the car. Very not keen on removing the fuel tank at the moment, I'll probably line this up for when I eventually do my rear subframe bushes.
