Hi I got a heap of RB20det parts and R32 Skyline parts out of a 1993 model R32 Gtst which only had
82,000km on it.
RB20det Parts / Driveline Parts:
Throtle body with sensors $50
Intake manifold with all sensors $80
Fuel Rail with injectors $80
Starter motor $70
Alternator $70
Power steering pump with bracket and pulley $100
Air con compressor $70
Air con compressor bracket with adj pulley $40
Coil Packs $80
Coil pack loom $60
Engine mounts $50 each
Stock turbo with front pipe $350
Stock turbo water/oil lines $50
Stock turbo actuator $70
Stock turbo dump to cat $30
Stock cat $30
Crossover pipe with BOV mount $50
Stock intercooler piping (underbonnet) $50
Clutch Fan $50
Brake Booster $40
H20 Sensor $50
RB20det 5 speed gearbox $500
RB20det manual tail shaft $100
R32 Skyline parts:
Gtst Bonnet (Silver) $100
Drivers Seat $50
Rear Seat $50
Spare wheel cover $20
Drivers door (Black) $50
Drivers Power window motor $80
Rear discs and calipers $60 set
Interior light $10
Rear view mirror $20
Stereo brakets + Compartment $20
Left side Electric mirror $50
Right side rear quarter trim (bottom half) $20
Drivers side guard liner $10
Centre Console tunnel surround $10
Pioneer stereo CD player 200w detach face $20
Base 10" sub 500w in box $20
Scuff plates $20 pair
Indicator stalk (whole mechanism) $80
Windscreen wiper motor $50
Boot Lid (Black) Slight repairable damage $30
Rear SKYLINE garnish in black. Letters are mirrors. Looks awesome and very rare to find $150
Im located in ASHFIELD (SYDNEY)
Postage can be arranged at buyers expense
PM or contact me on 0415 126 075
Regards Sam
https://www.sau.com.au/forums/topic/312136-rb20det-r32-parts/
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
