Hey ppls.
I'm wondering if anybody has used the CES racing Twin Dump Pipe for their Skylines??
I currently have a Blitz Front pipe and am considering swapping to a twin dump but would like some feed back first....
Thanks
BASS OUT
https://www.sau.com.au/forums/topic/31215-ces-racing-exhausts/
I got a CES front/dump unit - seems good - got nuthing to compare it too though except my stock setup - But I got a bunch of mods done at the same time so I can't tell you the benefits in HP.
I can say that they look HOT and seem to be very well contructed
There is an article on CES in one of the latest mags ?? HPI, Zoom or sumthing !
There is a couple of guys up here in Brisbane that have got complete turbo back exhausts from CES. They all rave bout the quality of workmanship, but also mention that they are not cheap. You pay for what you get I guess. There is a little article in the latest HPI mag about their dump pipes.
I am thinking of getting their HPC dump pipes when the R arrives, they look very good.
I've got a front/dump from CES. Couldnt be happier with it. Awesome design. You can probably expect about 20rwkw over standard with a cat back.
With my existing cat back and K&N panel filter the car made 126rwkw@8psi. I put the dump/front on with a bleed valve@6psi and it still gave me 7rwkw extra! Thats right, less boost more power. I've now wound up the boost and the car is making 153rwkw.
They're a bit expensive but the quality is great.
Aha! i knew there was something more than just quality
sweet.
So the seperate wastegatepipe..
theres 2 pipes coming off the turbo,
the wastegate pipe is obviously smaller.. and joines back onto the main exhaust a bit later on
so this is called an internal wastegate yes?
the wastegate pipe doesnt get in the way or hit anything im assuming,
And whats the direct advantage over single pipe dumps?
Yep, 2 pipes that steer clear of all other engine components.
The advantage of having the twin system is it causes less turbulence in the exhaust when the wastegate and exhaust air combine. It allows smoother air flow which leads to more air getting out quicker.
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
