Hi Guys, i need some help with the temp sensor for my skyline...i have an R33 GTST 1995 Series 1.5
i remember some time a while ago i had the guage play up, just went really low or fliekered or something like that.
anyway i replaced the sensor and it was all out of whack... the guage read really high. so i just pulled the needle and 'recalibrated' it...:cool:
the genuine part from nissan is: 25080Y
recently i put a GTR dashin my car as i needed a new one (tacho and speedo playing up) and i have this issue back again... the temp needle reads right off the scale when the car is at temp (81degC)
now upon futher investigation (and using FAST) i have discovered that the temp sensors across the Skyline Range all seem to be the same one...
I am using the Tridon one (TTS036)
does anyone know where i should be looking if there is another issue? i mean its just a simple cicuit as far as resistance is concerned...
for the mean tim i am putting a resisitor inline to get it 'close'...
https://www.sau.com.au/forums/topic/312156-temp-guage-sender-issues/
Ok further to this, can someone please measure the voltage at the end of the blue wire that goes to their temp sender...measure between ground and also state your system voltage as well please and your car/engine. Thanks!
no, i have tried replacing the wire direct from the sender to the back of the guage... and the sender is a brandnew tridon one! (part number TTS036)
According to FAST and tridon, all RBs use the same sender for the guage.
if someone could give me their sender resistance when cold and when at 80deg that would be great.
also the voltage from the sender wire to ground...
mine reads 11V
when driving my alternator puts out 14.4V solid. idle is 13.5V
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
