I GOT A FEW BITS AND PIECES THAT ARE NO LONGER REQD ALL OFFERS CONSIDERED!!!
LOCATED SOUTHSIDE BRISBANE
RB20DET PARTS:
CAS (CRANK ANGLE SENSOR) semi polished looks good az
TOP HALF OF PLENUM x2
BOTTOM HALF OF PLENUM WITH INTAKE RUNNERS X2 SETS
1 SET OF STANDARD CON RODS
1 RB20DET CRANK IN GOOD CONDITION
5 STANDARD PISTONS IN GOOD NICK 1 COMPRESSED A SELF TAPPED SCREW SO NO GOOD
RB20DET STANDARD OIL PUMP
RB20DET JPIPE SEMI POLISHED WITH STAINLESS BLANK OFF PLUG LOOKS SWEET
INLET AND EXHAUST CAMSHAFTS X 2 SETS GOOD CONDITION ALSO HAVE CAM CAPS AND BOLTS IF NEEDED
RB20DET STANDARD TURBO NO SHAFT PLAY COMES WITH OIL FEED/BANJO BOLTS AND OIL DRAIN AND 8PSI RB25 ACTUATOR HAS THE COMPRESSOR COVER SEMI POLISHED LOOKS VERY TIDY THE EXHAUST HOUSING WAS SUBJECTED TO 3 COATS OF STEALTH BLACK HIGH TEMP PAINT RATED TO 650 DEGREES HAS BEEN RESEALED WITH HIGH QUALITY BLUE RTV SILICONE IS READY TO BOLT AND GO EXCELLENT CONDITION AND APPERANCE.
COMPLETE RB20DET STANDARD HEAD IN GOOD CONDITION STILL VERY SMOOTH AND HAS FACTORY MACHINE MARKS LOW K PERFECT FOR REPLACEMENT
COMPLETE RB20DET BOTTOM END IN GOOD NICK BOLT HEAD ON AND GO SPRAYED STEALTH BLACK HIGH TEMP PAINT CLEANED LOW K AND READY TO ROCK
RB26DETT CRANKSHAFT SUITABLE FOR RB24 BUILD OR 26 REPLACEMENT NO PROBLEMS WITH IT SMOOTH SURFACES ON JOURNALS ETC NEVER RUN A BEARING AT WORST COULD DO WITH A QUICK MICROPOLISH SUITED TO STANDARD SIZE BEARINGS.
RB20DET CAM COVERS 2X TOP COVER 1X BOTTOM COVER
RB20DET VALVE COVERS GOOD CONDITION 2 SETS AVALIABLE
ALL IN GOOD WORKING CONDITION POSTAGE CAN BE ORGANISED JUST ENQUIRE OFFERS AND SWAPS FOR THINGS OF INTEREST ALWAYS CONSIDERED
https://www.sau.com.au/forums/topic/312174-rb20det-parts/
price on cam covers
valve covers
and RB26 crank
please
ok prices for you
valve covers 30
cam covers 40
rb26 crank 250 ono
will do package price on all that if you want too
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5143119
  • 3 weeks later...
just got in complete rb20det turbo engine has 126ks had 100k service done at 95k by nissan japan very good condition sell/swap doesnt have coilpacks ignitor or loom good replacement can come fitted with rb26 injectors also
call text pm or post 0450 728 189
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5175937
  • 5 months later...
Hi there!
Do you have a crankshaft in good condition?
In case you have, would you be interested in shiping one to sweden?
Its impossible to get over here!
Best regards! Markus
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5468782
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
